Limitation in sending multiple data values
Hi!, in sentences like Blynk.virtualWrite(pin, value1, value2, value3 …); which is the limit in the size/number of values you can send to a local server??? thanks
Hell. There are some hardware limits (max number of bytes you can send). And no restrictions on server side.
Hi @Dmitriy … thanks for your response … you mean BLYNK_MSG_LIMIT value, right?
Yeap, and MAX_SEND_BYTES
sorry @Dmitriy, where can i find some definition of that parameter? i could not find it on any doc. thanks
@fbt you can search this site for references to it. You can also search the libraries for this, or any, term you are unsure about.
http://docs.blynk.cc/#widgets-notifications-email see limitation section.
