Hello!
I have a Blynk project collecting data since Dic 13 of 2020, i generated a CSV report from the superchart widget and the CSV file only has data from 12/01/2021 to 22/01/2021. In the CSV there are 13500 data points.
In the app I can see the data since 13/12/2020.
So I want to know if there is a limit on the number of data points, file size or if Blynk can only store data for 10 days?
I assume that you are using the Blynk cloud servers?
That’s the limit imposed by the cloud servers. If you want to be able more data points then you’ll need to set up a local server.
Yes, i did not know that, thanks!
So if want to set up automatic reports and still use the Blynk cloud i should do it weekly?
If I use a local server is there still limits to the number of data points?
I’m not sure, but if you go for the Raw data storage option it creates a PostgreSQL database which presumably you can query. I seem to recall a few topics on the issue of you do some searching.
