Light switch with virtual pin
Hello:
I need your help please.
I need to turn on a light with the “Widgets” “Time Imput” which only works with virtual pins (not digital), I have the light connected to the physical D2 pin of the ESP8266 (LoLin). this is my sketch
Thank you in advance for your great help!
@leoquar8 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Hello:
Thank you very much for your quick response, I send code between ```
//#include <SimpleTimer.h>
#include <DHT.h>
char auth[] = “vlKIPDZ2Oz2E6T3qwyv9S******”; //Enter the Auth code which was send by Blink
// Set password to “” for open networks.
char ssid[] = “ITC”; //Enter your WIFI Name
char pass[] = “********”; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 4
// Uncomment whatever type you’re using!
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
void LUZ(){
int pinValue = !digitalRead(4);
//Serial.println(pinValue);
if (pinValue == 1) {
Blynk.virtualWrite(V10, HIGH); //coloca a 1
Blynk.virtualWrite(V10, LOW); // coloca a 0
dht.begin();
Use the sketch builder time input example. In if statement do a digital write to your D2 pin. After that it should be pretty easy to add your DHT code to that.
Thank you very much for your answer daveblynk, what I do not understand is how to indicate to my program that the virual pin 10 corresponds to the physical pin D2. I would appreciate your help with this. Thank you
When the state of V10 changes, the callback function BLYNK_WRITE(V10) will be executed.
If you add this callback function to your code then you can then extract the value from the V10 widget using x=param.asInt()
x can then be tested to see if it is an On (1) or Off(0) and a digitalWrite(HIGH) or (LOW) used to control the status of your physical pin.
If you take a look at the examples in the Sketch Builder you’ll see how this works, and incorporate those examples into your code.
