LED widget on blynk wont turn on, i am using 10 IR sensor that are connect to ArduinoMEGA in addition to the NodeMCU 8266
char ssid[] = "HUAWEI-E6878-C595";
char pass[] = "@Sameera123";
String myString; // complete message from arduino, which consistors of snesors data
char rdata; // received charactors
int GF_firstVal, GF_secondVal, GF_thirdVal, GF_fourthVal, GF_fifthVal, FF_firstVal, FF_secondVal, FF_thirdVal, FF_fourthVal, FF_fifthVal; // sensors
int led1,led2,led3,led4,led5,led6,led7,led8,led9,led10;
// This function sends Arduino's up time every second to Virtual Pin (1).
void myTimerEvent()
  Blynk.virtualWrite(V1, millis() / 1000);
    timer.setInterval(1000L,sensorvalue1);
    timer.setInterval(1000L,sensorvalue2);
    timer.setInterval(1000L,sensorvalue3);
    timer.setInterval(1000L,sensorvalue4);
    timer.setInterval(1000L,sensorvalue5);
    timer.setInterval(1000L,sensorvalue6);
    timer.setInterval(1000L,sensorvalue7);
    timer.setInterval(1000L,sensorvalue8);
    timer.setInterval(1000L,sensorvalue9);
    timer.setInterval(1000L,sensorvalue10);
   if (Serial.available() == 0 )
  if (Serial.available() > 0 )
    rdata = Serial.read();
    myString = myString+ rdata;
   // Serial.print(rdata);
    if( rdata == '\n')
     Serial.println(myString);
// new code
String l = getValue(myString, ',', 0);
String m = getValue(myString, ',', 1);
String n = getValue(myString, ',', 2);
String o = getValue(myString, ',', 3);
String p = getValue(myString, ',', 4);
String q = getValue(myString, ',', 5);
String r = getValue(myString, ',', 6);
String s = getValue(myString, ',', 7);
String t = getValue(myString, ',', 8);
String u = getValue(myString, ',', 9);
// these leds represents the leds used in Blynk application
led1 = l.toInt();
led2 = m.toInt();
led3 = n.toInt();
led4 = o.toInt();
led5 = p.toInt();
led6 = q.toInt();
led7 = r.toInt();
led8 = s.toInt();
led9 = t.toInt();
led10 = u.toInt();
  myString = "";
// end new code
void sensorvalue1()
int sdata = led1;
  Blynk.virtualWrite(V10, sdata);
void sensorvalue2()
int sdata = led2;
  Blynk.virtualWrite(V11, sdata);
void sensorvalue3()
int sdata = led3;
  Blynk.virtualWrite(V12, sdata);
void sensorvalue4()
int sdata = led4;
  Blynk.virtualWrite(V13, sdata);
void sensorvalue5()
int sdata = led5;
  Blynk.virtualWrite(V14, sdata);
void sensorvalue6()
int sdata = led6;
  Blynk.virtualWrite(V15, sdata);
void sensorvalue7()
int sdata = led7;
  Blynk.virtualWrite(V16, sdata);
void sensorvalue8()
int sdata = led8;
  Blynk.virtualWrite(V17, sdata);
void sensorvalue9()
int sdata = led9;
  Blynk.virtualWrite(V18, sdata);
void sensorvalue10()
int sdata = led10;
  Blynk.virtualWrite(V19, sdata);
// Function used to split string message using comma
String getValue(String data, char separator, int index)
    int found = 0;
    int strIndex[] = { 0, -1 };
    int maxIndex = data.length() - 1;
    for (int i = 0; i <= maxIndex && found <= index; i++) {
        if (data.charAt(i) == separator || i == maxIndex) {
            found++;
            strIndex[0] = strIndex[1] + 1;
            strIndex[1] = (i == maxIndex) ? i+1 : i;
    return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
Please edit your post and add triple backticks ( ``` ) before and after your sketch.
@Samiixv please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
I have no idea what sort of values you are writing to the LEDs when you do this…
but an LED widget requires a value of 255 to turn it on at full brightness.
As for the rest of your code, it’s a total mess with a cluttered void loop and 10 timers that are all being called simultaneously.
You should check this out
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
The ideal blynk void loop should look like this
