Led Blynk receive result from an if
I’m from Brazil, and I’m using google translator, so sorry for the typos.
I have a Blynk application with my NodeMcu,
I’m trying to connect Blynk’s LEDs after a check, how can I do it?
I’m going to put my code and a (?) where I would put a function so that the led of BLYNK received the result.
   if(digitalRead(boia) == 0)
     lcd.setCursor(0,1);
     lcd.print("NIVEL BAIXO");
     lcd.setCursor(0,1);
     lcd.print("NIVEL OK");
I was able to solve the problem IN VOID LOOP()
     lcd.setCursor(0,1);
     Blynk.virtualWrite(V0, 255);
     Blynk.virtualWrite(V1, 0);
     lcd.setCursor(0,1);
     Blynk.virtualWrite(V0, 0);
     Blynk.virtualWrite(V1, 255);
That is not a solution. Suggest you study the PUSH_DATA example for how to call functions at timed intervals.
I have refactored by removing “void loop ()”, below my code.
/* DS18B20 Temperature Sensor */
#include <OneWire.h>
#define ONE_WIRE_BUS 2 // DS18B20 on arduino pin2 corresponds to D4 on physical board
// Inicializa o display no endereco 0x27
LiquidCrystal_I2C lcd(0x3F, 16, 4);
//NOVO
float temp;
int tempmin = 99;
int tempmax = 99;
int boia = 16;
char auth[] = "7bd7d74d1df847f4915433f06bbb3bc6";
char ssid[] = "REDE DS";
char pass[] = "1234554321";
char ssid[] = "LoVeS";
char pass[] = "123ab456cd";
char ssid[] = "CHICOS";
char pass[] = "a1b1c1d1e1";
void myTimerEvent()
     lcd.setCursor(-2,3);
     digitalWrite(D7, LOW);
     digitalWrite(D7, HIGH);
  sensors.requestTemperatures();       //Prepare the sensor for reading
  temp = sensors.getTempCByIndex(0);
  Serial.println(temp);
    Serial.println(tempmin);
      Serial.println(tempmax);
   if(tempmin > temp)
     digitalWrite(D8, HIGH);
   if(tempmax < temp)
     digitalWrite(D8, LOW);
  // ----Mostra dados no LCD----
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Temp.:       ");
  //Simbolo grau
  lcd.write(223);
  lcd.print("C");
  lcd.setCursor(7,0);
  lcd.print(temp);
  lcd.setCursor(0,1);
  lcd.print("Temp.Min.:   ");
  lcd.write(223);
  lcd.setCursor(11,1);
  lcd.print(tempmin);
  lcd.setCursor(14,1);
  lcd.print("C");
  lcd.setCursor(-4,2);
  lcd.print("Temp.Max.:   ");
  lcd.write(223);
  lcd.setCursor(7,2);
  lcd.print(tempmax);
  lcd.setCursor(10,2);
  lcd.print("C");
  Blynk.virtualWrite(10, temp); //virtual pin V10
  pinMode(boia,INPUT);
  lcd.init();   // INICIALIZA O DISPLAY LCDLCD
  lcd.backlight(); // Enable or Turn On the backlight
  sensors.begin();
BLYNK_WRITE(V11) //Set Temperature Button
tempmin = param.asInt();
BLYNK_WRITE(V12) //Set Temperature Button
tempmax = param.asInt();
 * Send Sensor data to Blynk
Thank you for your attention.
What do you think of the new code?
Please see how I edited your post with formatted code.
Your changes are correct. You have used a timer to send Blynk VirtualWrites which is good practise.
Enormous improvement.
thanks for the help, friends.
I’m having a problem with my application.
1- My level sensor is only activating the relay if I put a button as a switch and click once, then the relay works normally. It’s like you need a start.
2- I turned on the door that triggers a relay to show me if it is on or off if the level is low, everything is working normal, but the button is not receiving the values of 0 or 1.
Thanks for the help.
Maybe the relay is active LOW, most are. You can switch the on and off in the app.
My level sensor:
2- I put a button(in blynk) on the door that activates a relay to show me if it is on or off if the level is low, everything is working normal, but the button is not receiving values of 0 or 1.
Buttons don’t tend to act as displays by default… are you refering to using Blynk.virtualWrite(vPin, value) and/or Blynk.setProperty(vPin, “property”, value). If so, just follow the Documentation and also look at this Sync Physical Button example sketch for the general principle.
Could it be a wiring problem? Or a problem with a “floating value” because you do not have a pull up/down resistor in your circuit? How are you activating the relay? Do you have the proper voltage and current for the relay coil coming from your microprocessor?
I’ll try thank you.
everything is ok with the wiring and so on.
How do I set the I2C RTC to the current time and date and send it to the Blynk?
using NodeMcu
Sounds like a new thread.
I’m create the New Topic.
Thank you.
