LED blink wont work
hello am using photon and I cant get the LED example to blink my LED in the APP
whats wrong with me code ?
#include "SparkCorePolledTimer/SparkCorePolledTimer.h"
#include "blynk/blynk.h"
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * Blynk using a LED widget on your phone!
 * App project setup:
 *   LED widget on V1
 * WARNING :
 * For this example you'll need SimpleTimer library:
 *   https://github.com/jfturcot/SimpleTimer
 * Visit this page for more information:
 *   http://playground.arduino.cc/Code/SimpleTimer
char auth[] = "af4a41b131974d91bbaac4d7a3709d4c";
WidgetLED led1(V1);
  Blynk.begin(auth);
    // Wait until connected
// V1 LED Widget is blinking
void blinkLedWidget()
  if (led1.getValue()) {
    led1.off();
    Serial.println("LED on V1: off");
    led1.on();
    Serial.println("LED on V1: on");
The Timer function is missing, try this code:
WidgetLED led1(V1);
  Blynk.begin(auth);
    led1.off();
    led1.on();
Regards!
borther I tried ur code it doesn’t compile
it says
vp.cpp:14:25: fatal error: SimpleTimer.h: No such file or directory
#include “SparkCorePolledTimer/SparkCorePolledTimer.h”
the simpletimer.h they use it for Arduino if am not mistaking .
am using particle photon ,that’s what am facing the problem .
You have to add the SparkCorePolledTimer throuth the WebIDE UI to bind it to the library correctly.
Hope that helps.
hello sir .
i do go to build ide then librares then in search i type blynk included to the code then i search for sparkcorepulledtimer and i included to the code .but wen i compile it i wont it gives me this error
In file included from blynk/BlynkParticle.h:16:0,
                 from blynk/BlynkSimpleParticle.h:14,
                 from blynk/blynk.h:2,
                 from vp.cpp:5:
blynk/BlynkApiParticle.h:87:6: warning: #warning "analogInputToDigitalPin not defined => Named analog pins will not work" [-Wcpp]
 //#include "SparkCorePolledTimer/SparkCorePolledTimer.h"
compilation terminated.
make[1]: *** [../build/target/user/platform-6vp.o] Error 1
make: *** [user] Error 2
how i can include simpletimer ?? plz show me how thank u sir
On Particle you need to use other library for timed events. Sparkpolled timer or smth like that.
  1. Learn how this library it works - they have example sketch
  2. Include it in your sketch with Blynk
  3. Use it for timed events to send data to Blynk.
