LCD Widget properties
How can I change LCD properties like Screen color or Text color?
Blynk.setProperty(V1, “color”, “#41C2E1”) <<< HEXA code
font color you can not believe only black or white
#include <Ethernet.h>
WidgetLCD lcd(V1);
  Blynk.begin(auth);
  lcd.clear(); //Use it to clear the LCD Widget
  lcd.print(4, 0, "Hello"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
  lcd.print(4, 1, "World");
   Blynk.setProperty(V1, "color", "#41C2E1") //HEXA color code
  // Please use timed events when LCD printintg in void loop to avoid sending too many commands
  // It will cause a FLOOD Error, and connection will be dropped
yes, that’s it. Thanks a lot.
