LCD widget pins are line specific
It seems you can only use pin0 on line 1and pin1 on line 2, this seems very confusing, since they are tokens i would think they could be used in either line. The UI does not hint that this is the case either, maybe either change the behavior or add the ind colors to the line outlines or something
If it’s iOS, it’s fixed already and will be available in next update.
Thanks for reporting.
