Hardware: Particle Photon (Firmware: v0.5.1)
iOS: 9.3.2
Widget: LCD
If there is an attempt to write to the LCD beyond 16 characters it results in a buffer overflow and reboots the photon.
Example:
lcd.print(0, 1, "Signal Strength: " + String(wifiSignal));
Obviously I made the mistake since “Signal Strength:” eats all 16 character places. But I would think it would make sense for the LCD widget to truncate or display error instead of putting photon into a reset loop.
Rick
@vshymanskyy is that our bug?
I may have been a bit premature on the conclusion. It is not due to surpassing the 16 character limit. It appears to have to do with combining output with the + operator. I have tested a bit beyond that but do not have a resolution.
Example that will fail:
lcd.print(0, 1, "Signal: " + wifiSignal);
Example that will work:
lcd.print(0, 1, "Signal: ");
lcd.print(8, 1, wifiSignal);
Note: This also causes issues in the terminal widget. Different there and I will elaborate if necessary.
Hope this helps.
Rick
