Greetings. First of all, my english is not very good, but i’m gonna try my best.
I’m trying to use the LCD Widget in advanced mode, and i’m following the example from github. The code looks like this:
In void setup, i put:
WidgetLCD lcd(V3);
In void loop, i put:
lcd.clear();
lcd.print(0,0, "Texto de prueba"); (not only in 0,0, but other coordinates as well)
When i try verifying the code or uploading it in my NodeMCU, it shows the error message:
> In function 'void loop()':
> NodeMCU_prueba_humedad:83: error: 'lcd' was not declared in this scope
> lcd.clear();
> exit status 1
Of course, i tried renaming the “lcd”, for example: “WidgetLCD lcd1(V3)” and renamed the instruction to “lcd1.print”, but i have the same problem.
Any help will be welcome. Thanks
