Lcd Blynk Problem
Hi, I want to include a LCD widget in my project. I am using a particle photon. When i flash this example:
it only write the second line. never the first. I use a timer to refresh the lcd every 60s.
But if i include lcd.print() inside the loop it works.
You don’t want a function like lcd.print() in your loop().
Do you have LCD widget set in advanced or simple mode.
Perhaps post the minimum sketch that reproduces your observation.
This is a bug. We will release update with fix soon.
Ok. i wait for the solution
