You can modify the code as follows:
void SquareWave(int pin,
unsigned long offtime,
unsigned long ontime,
int Vpinled,
float flow1,
float flow2)
// to pass parameters to lambda function. You can use global vars
static int _pin = pin;
static int _Vpinled = Vpinled;
static float _flow2 = flow2;
analogWrite(pin, flow1);
Blynk.virtualWrite(Vpinled, 0);
timer.setTimeout(ontime, []()
analogWrite(_pin, _flow2);
Blynk.virtualWrite(_Vpinled, 255);
Lambda function, if using parameters, not global or static, inside the function, is a little bit complicated, and will create non-captured errors as you experienced. If you need more info, please read
https://en.cppreference.com/w/cpp/language/lambda
captures - a comma-separated list of zero or more captures, optionally beginning with a capture-default.
See below for the detailed description of captures.
A lambda expression can use a variable without capturing it if the variable
- is a
non-localvariable or hasstaticor thread local storage duration (in which case the variable cannot be captured), or - is a reference that has been initialized with a constant expression.
A lambda expression can read the value of a variable without capturing it if the variable
- has const non-volatile integral or enumeration type and has been initialized with a constant expression, or
- is constexpr and has no mutable members.
