Using Arduino IDE and ESP32.
Iphone 6 iOS 14.2
Blynk Server (I think)
Blynk Library 0.6.1
Example is using
Board ESP32
Connection ESP32 WiFi
Auth Token left empty
Example Push data
Using code from “Keep you void loop() clean”, Blynk logo and then data from sensorValue is written to Serial Monitor, but nothing seems to appear in the Blynk App. I think I have followed what was said in the example
This is my first go, so maybe I don’t understand the app - apologies!
Blynk App is called Testing and just shows a blank screen under the green header.
code:
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "SagGBdQ5-2Pv3T9cuCbB_77hY0drmutM";
char ssid[] = "BT-25AHS2";
char pass[] = "*******"; // my actual pWord entered here; not included for safety!
int sensorValue;
void myTimerEvent()
sensorValue = analogRead(A5);
Serial.print("Sensor is: ");
Serial.println(sensorValue);
