Hi friends. the problem with the below code with JS script. any way to fix ?
thanks
the error:
module.js:549
throw err;
Error: Cannot find module 'blynk-library'
at Function.Module._resolveFilename (module.js:547:15)
at Function.Module._load (module.js:474:25)
at Module.require (module.js:596:17)
at require (internal/module.js:11:18)
at Object.<anonymous> (/home/pi/test.js:1:75)
at Module._compile (module.js:652:30)
at Object.Module._extensions..js (module.js:663:10)
at Module.load (module.js:565:32)
at tryModuleLoad (module.js:505:12)
at Function.Module._load (module.js:497:3)
the JS code
var Blynk = require('blynk-library');
var AUTH = '90d28c96e66f49868cdcb9868c760be0';
var blynk = new Blynk.Blynk(AUTH, options = { connector : new Blynk.TcpClient( options = { addr:"10.5.50.18", port:8080 } ) });
var exec = require('child_process').exec, child;
var v0 = new blynk.VirtualPin(0);
var v1 = new blynk.VirtualPin(1);
var v2 = new blynk.VirtualPin(2);
var v3 = new blynk.VirtualPin(3);
var slider = new blynk.VirtualPin(4);
var writeVal = '';
//volume control using slider
slider.on('write', function(param) {
child = exec('amixer set PCM ' + param[0] + '%',
function (error, stdout, stderr) {
console.log('stdout: ' + stdout);
console.log('stderr: ' + stderr);
if (error !== null) {
console.log('exec error: ' + error);
//turn on squeezelite turn off others
v1.on('write', function(param) {
if (param[0] == '1') {
child = exec('sudo /etc/init.d/squeezelite start',
writeVal = 'squeezelite ON';
else if (param[0] == '0') {
child = exec('sudo /etc/init.d/squeezelite stop',
writeVal = 'squeezelite OFF';
v2.on('write', function(param) {
child = exec('sudo systemctl start shairport-sync',
writeVal = 'shairport ON';
child = exec('sudo systemctl stop shairport-sync',
writeVal = 'shairport OFF';
v3.on('write', function(param) {
child = exec('ecasound -C -q -B:rt -b:1024 -f:16,2,48000 -i:alsahw,1,0',
writeVal = 'analog ON';
child = exec('sudo killall -15 ecasound',
writeVal = 'analog OFF';
v0.on('read', function() {
v0.write(writeVal);
but the library working:
pi@raspberrypi:~ $ blynk-client a6d6a08f382a4d60bd348707bfdee103
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/
Give Blynk a Github star! => https://github.com/vshymanskyy/blynk-library-js
Connecting to: blynk-cloud.com 8441
SSL authorization...
Connected
Authorized
Blynk ready.
