Hi I am using an Iphone 8 with the latest IOS.
I have a robot drive project using the joystick.
The home values are 511 511.
When I touch the stick with my thumb the values stay at 511 511.
However as I move my thumb up in the positive direction (intending to drive the robot forward), the y value actually drops down to around 350 instead of increasing!
This causes my robot to actually drive backwards momentarily until I continue to slide my thumb up and the value then jumps to a value above 511. At this time the robot drives forward.
This issue is easy to see as the widget shows the x,y values on the screen.
The x values appear to work correctly.
Not sure if this problem exists on the android client.
