Joystick + 2 buttons
Here is my code:
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * This example shows how to use Arduino Yun Bridge
 * to connect your project to Blynk.
 * Feel free to apply it to any other example. It's simple!
#include <Bridge.h>
#include <BlynkSimpleYun.h>
char auth[] = "Auth Token substitued";
  Blynk.begin(auth);
  // Or specify server using one of those commands:
  //Blynk.begin(auth, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, server_ip, port);
// This function will be called every time
// when App writes value to Virtual Pin 1
BLYNK_WRITE(V1)
  Serial.print("Got a value: ");
  Serial.println(param.asStr());
  // You can also use:
  // int i = param.asInt() or
  // double d = param.asDouble()
// when App writes value to Virtual Pin 2
BLYNK_READ(V2)
BLYNK_WRITE(V3) {
  Blynk.virtualread();
  int x = param[0].asInt();
  int y = param[1].asInt();
  // Do something with x and y
  Serial.print("X = ");
  Serial.print(x);
  Serial.print("; Y = ");
  Serial.println(y);
How can i solve the problem:
C:\Users(…)\Arduino_Yun\Arduino_Yun.ino: In function ‘void BlynkWidgetRead2(BlynkReq&)’:
Arduino_Yun:57: error: ‘param’ was not declared in this scope
Hello. Does simple sketch without your code compiles fine?
What is that?
