I've been getting the following issue on using Blynk
Neopixel ‘strandtest’ working fine offline. When I am trying to connect the same to Wifi using ESP8266 with Blynk, I’m getting the following error while compiling-
Arduino: 1.6.7 (Windows 10), Board: “NodeMCU 1.0 (ESP-12E Module), 160 MHz, 115200, 4M (3M SPIFFS)”
Build options changed, rebuilding all
C:\Users\Vibhor\Documents\Arduino\sketch_may11a\sketch_may11a.ino: In function ‘void loop()’:
sketch_may11a:50: error: ‘colorWipe’ was not declared in this scope
 colorWipe(strip.Color(255, 0, 0), 50); // Red
C:\Users\Vibhor\Documents\Arduino\sketch_may11a\sketch_may11a.ino: In function ‘void rainbow(uint8_t)’:
sketch_may11a:68: error: ‘Wheel’ was not declared in this scope
   strip.setPixelColor(i, Wheel((i+j) & 255));
C:\Users\Vibhor\Documents\Arduino\sketch_may11a\sketch_may11a.ino: In function ‘void rainbowCycle(uint8_t)’:
sketch_may11a:81: error: ‘Wheel’ was not declared in this scope
   strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
C:\Users\Vibhor\Documents\Arduino\sketch_may11a\sketch_may11a.ino: In function ‘void theaterChaseRainbow(uint8_t)’:
sketch_may11a:111: error: ‘Wheel’ was not declared in this scope
     strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
exit status 1
Here’s my code-
#include <Adafruit_NeoPixel.h>
#ifdef AVR
#include <avr/power.h>
#endif
#define PIN 5
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic ‘v1’ (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(120, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel’s data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit…if you must, connect GND first.
char auth = “xxx”;
int k=5;
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (AVR_ATtiny85)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
Blynk.begin(auth, “Connectify-P”, “vibhor8539”);
strip.begin();
strip.show(); // Initialize all pixels to ‘off’
BLYNK_WRITE(V1)
k = param.asInt();
// Some example procedures showing how to display to the pixels:
colorWipe(strip.Color(0, 255, 0), 50); // Green
colorWipe(strip.Color(0, 0, 255), 50); // Blue
// Send a theater pixel chase in…
theaterChase(strip.Color(127, 127, 127), 50); // White
theaterChase(strip.Color(127, 0, 0), 50); // Red
theaterChase(strip.Color(0, 0, 127), 50); // Blue
rainbow(20);
rainbowCycle(20);
theaterChaseRainbow(50);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.show();
delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
for (int j=0; j<10; j++) { //do 10 cycles of chasing
for (int q=0; q < 3; q++) {
for (int i=0; i < strip.numPixels(); i=i+3) {
strip.setPixelColor(i+q, c); //turn every third pixel on
strip.show();
  delay(wait);
    strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
for (int j=0; j < 256; j++) { // cycle all 256 colors in the wheel
strip.show();
  delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Please edit your post, and insert code using </> editor button…
