Issues with API Service on command "Get for Digital pin" on (Nodemcu)
i use latest local server and Android APP So i have a issues with this command this value not true:
http://192.168.1.2:8080/AUTH-Token/get/D0
when i change the value to “0” it(The above Link) shown “1” and it’s not true.
same Problem with Other Digital Pin on Nodemcu.
I try many Time but Doesn’t Fix. And on Old Version Too.
so how can i use https://LocalAddress/auth_token/notify
to push notify???
That’s because you should be working to GPIO references not the strange “D” references that NodeMCU and others have on their boards.
Covered in the docs at blynkapi · Apiary
Basically a POST not a GET command with the message text in the body of your post.
so you mean http://192.168.1.2:8080/AUTH-Token/get/GPIO16 will be work?
or
http://192.168.1.2:8080/AUTH-Token/get/D16
but dose not work
Just a simple 16.
http://192.168.1.2:8080/AUTH-Token/notify
doesn’t work
" Wrong pin format."
That’s because it’s not the syntax in the API.
It requires POST and a body.
Actually the GET pin value does use the D for digital but not D for NodeMCU labels.
to use API Get for Digital pin it require a widget assigned to that Pin or Blynk send (digitalRead) command?
I mean that requre some code or Blynk do it?
Syntax is /D16 for GPIO 16 (labelled D0 on your hardware) but you must have digital (GPIO) pin 16 in your project.
