Issue with "reset" button in widget Time Input
Oh… for crying out loud :roll_eyes:… OK, a bit of a face palm for myself… and big a “why the bleep didn’t you add in this little tidbit at the beginning” for you :stuck_out_tongue_winking_eye: The widget DOES show either - -:- - or 00:00 depending on how you use the reset function…
In my limited defense, I really don’t use the Time Input Widget for my projects… nothing I use requires such specific timing… so while I did poke at the reset for the purposes as I described above, I never actually SAVED the reset settings and thus never noticed what you only just now mentioned.
Therefore… if you actually want to use the reset as a null time for whatever reasons that you still haven’t made clear, then use the Boolean results from these two commands to determine if the Start/Stop time is - -:- - (there is a NULL after all :blush: just not in the actual time calculations) or 00:00 (midnight).
t.hasStartTime()
t.hasStopTime()
E.G…
BLYNK_WRITE(vPin) {   // Time Input widget Scheduler
  TimeInputParam t(param);
  if (t.hasStartTime() == 0) {
    // Start time is NULL
    // do NULL stuff
    // Start time is valid number... including 00:00
    // do start time stuff
