I am running blynk laster version 0.27.1 on my local server(Ubuntu server). Most of the things are works fine. Now I am getting the issue on History Graph CSV Download. When I click the “Export to CSV” button it takes me to Export data popup message and the popup message says “CSV file will be sent to your email address” and once I clicked the continue button then it says “No Data”
Note: I have installed postfix on my local server and enabled following values on my server.properties file
#enable DB
enable.db=true
#enable raw data storage to DB
enable.raw.db.data.store=true
Yes, I have lots of free space in my local blynk server.
Usually, anyone can write data in /tmp directory. Also, I can see history data’s are written in the data folder. So I don’t think writing is causing the issue.
If possible you can give the debug build I can try with this.
I think I found the problem. Problem coming from /tmp/blynk directory. Actually, this folder has root uer access but I am runing blynk on another user. So, its my mistake.
