Itās maybe easier to call setInterval and the likes in the functions themselves. There is no need to do it in setup(). It makes you even more inflexible. You can set the interval, timeout or enable/disable timers from everywhere
I see now, I think I looked at it before the coffee, LOL.
If it works, it works. I think itās fine like this. With my latest project (which I abandoned quickly) I use a single timer to start other timers, that is too say, I have a function to enable all timers and this function is called ONCE with a setTimeout. This is made to start running function after I completed all the setup parts.
Imagine you want to synchronize time first and then start running your ānormalā code. You canāt do that in the setup() because the time sync has to take place from the Blynk.run() part.
Your code could probably be a bit shorter and everything can be in one function if you set flags to display what you want. E.g. displayCooktime = 1 (or 0) and make a switch or if statement.
Iām sorry, your question stated if there was simpler way, so I assumed it worked. The timeout runs only once! So if you set displayFreq to 5, it waits 5000ms before it executes, so it will always execute one time and I assume that is not what you want.
Can someone please tell me what the āLā is doing in the interval? Iāve looked through this forum, and the documentation at Arduino Playground - HomePage and canāt find any reference as to what the āLā is for, and what other options might be available.
L stands for Long which is a data type bigger than an integer. If you want the timer to run every 60 days it will be a number of milliseconds greater than you can hold in an integer variable.
Convention is that the Timer interval is shown as xL milliseconds irrespective of the duration but you could drop it if the hardware you are using can handle the integer size. ESPās (32bit) and Arduinoās (most are 16bit) have different integer sizes.
You wouldnāt be using a double as there isnāt a floating point aspect to a millisecond.
thanks everyone for your considered and helpful responses, but unfortunatly it really seems that there might be something in other parts of my code that are disrupting the simpleTimer for the display section. (weird!)
so i have moved the displayUpdate call to the end of another function (the temperature update section) that is called every 5 seconds, and the display sequence works without disruptionā¦
[if anyone is interested i can post the two full sets of code for analysis, but at least it is now workingā¦ ]
