I can input the data I want but if the board reboots it doesn’t remember the the data and i have to do it again from the numeric input again.
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
Feel free to apply it to any other example. It's simple!-
#include <ESP8266mDNS.h> // For OTA w/ ESP8266
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
// char auth[] = "oiXdJdY-cmz1WbZfr7o1SdUgncXJBCQF";// House Tank
char auth[] = "x3HDpMHpx8odgd2aKsSSR-d_TeYxWWjR";// Garage Tank
char ssid[] = "*****";
char pass[] = "*****";
int port = 8080;
// defines pins numbers
// trigpin on board is d14, echo is d15
const int trigPin = 4;
const int echoPin = 5;
int relayPin = 13;// define output pin for relay (13 = MOSI)
// defines variables
BlynkTimer timer; // Announcing the timer
long duration;
float sheight;
float capacity;
float height;
float pumptime;
float distance;
float percentageFull;
float finalPercentage;
float finalcapacity;
Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,84), 8080);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Inputs
pinMode(relayPin, OUTPUT); // Sets the relayPin as an Output
digitalWrite(relayPin, HIGH); // Sets relayPin to HIGH
timer.setInterval(15000L, sensorDataSend); //timer will run every sec (changed 500 1/2 a sec to 15000 15 secs)
// ArduinoOTA.setHostname("House Tank");
ArduinoOTA.setHostname("Garage Tank");
ArduinoOTA.begin(); // For OTA
void sensorDataSend()
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
// Calculating the distance
distance= duration*0.034/2;
distance= distance-sheight;
percentageFull=(distance/height);
finalPercentage=(1-percentageFull)*100;
finalcapacity= (1-percentageFull)*(capacity*100);
/* Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
Serial.print("percentagefull: ");
Serial.println(percentageFull);
Serial.print("finalPercentage: ");
Serial.println(finalPercentage);
Serial.print("finalcapacity: ");
Serial.println(finalcapacity);
//delay(5000);
Blynk.virtualWrite(V0, finalPercentage);
Blynk.virtualWrite(V1, finalcapacity);
// distance= 0;
// percentageFull= 0;
// finalPercentage= 0;
// finalcapacity= 0;
BLYNK_WRITE(V2) // Virtual button on Vx to activate action
int pinvalue = param.asInt();
int buttonState = param.asInt();
if (pinvalue == 1) {
digitalWrite(relayPin, LOW); // Set pin low
Blynk.virtualWrite(V2, 1);
timer.setTimeout((pumptime*60000L), relayOFF); // Run ActionOFF function in 5 seconds
if (pinvalue == 0) {
digitalWrite(relayPin, HIGH); // Set pin high
Blynk.virtualWrite(V2, 0);
void relayOFF()
BLYNK_WRITE(V3) // Reset
if (param.asInt()==1) {
delay(3000);
ESP.reset();
delay(5000);
BLYNK_WRITE(V4) //input from Numeric Widget for time pump runs
pumptime = param.asInt(); // Assigning incoming value from pin V4 to variable
Blynk.virtualWrite(V14, pumptime); // V14 just to test it's working
Serial.println(pumptime);
BLYNK_WRITE(V5) //input from Numeric Widget for height of sensor above max water level
sheight = param.asInt(); // Assigning incoming value from pin V5 to variable
Blynk.virtualWrite(V11, sheight); // V11 just to test it's working
Serial.println(sheight);
BLYNK_WRITE(V6) //input from Numeric Widget for max capacity of tank in L
capacity = param.asInt(); // Assigning incoming value from pin V6 to variable
Blynk.virtualWrite(V12, capacity); // V12 just to test it's working
Serial.println(capacity);
BLYNK_WRITE(V7) //input from Numeric Widget for height of water from bottom of tank to max water level
height = param.asInt(); // Assigning incoming value from pin V7 to variable
Blynk.virtualWrite(V13, height); // V13 just to test it's working
Serial.println(height);
BLYNK_WRITE(V99) // Virtual button on Vx to activate action
Blynk.run(); // run Blynk magic
timer.run(); // run timer every second
ArduinoOTA.handle(); // For OTA
