I’m on the plus plan and want to add a third (ESP32) device, i can only do this manually by adding to an excisting template but i don’t want that… I want a new third tile, just like the other two.
Is there a limitation?
You can Create more than 2 templates in PLUS plan.
In web console, select the Templates section/page on the left. In this page you should see a button “New Template”.
Edit: you need to start on WEB to Create template and datastreams and get auth. Then you switch to mobile to design your “template”. (If, I myself has not misunderstood.)
Even with the free plan, which is limited to 2 devices, you can create more than two templates.
Are you trying to do this in the web console?
Are you selecting an existing template and duplicating it, or are you creating a new one from scratch?
What message do you see when trying to create a new template, or are you simply missing the “+ New Template” button?
Do you have Developer Mode turned on for your user, and does that user have an Admin role?
My apologies. Must have been to late last night, on the template page (on web) i can add a new template (of course) …I was trying to directly add a new device.
