Is it possible to read any values and names from the widget table
Hey,I want to use the widget table to create a database which can update datas and I want to make the latest date at the top of the table(the former data becomes the second one,the second one becomes the third one…).So I have to read the value as well as the name of former data in table. Is it possible?
You may try to use SYNC command - https://docs.blynk.cc/#blynk-main-operations-get-data-from-hardware to get data from table.
However, for you goal I think you don’t need that, you may just decrease index every new table entry. Should work.
