IR sensor Issue
Hello there;
I have an issue with ir sensor. I made an ir sensor using TSOP2238 and with this sensor I can control a motor or selenoid valf. After that, I wanted to control the motor remotely using the Blynk app. and the problem started here. I am using NodeMCU v3 and Iphone 11pro as hardware. I wrote the software with the Arduino IDLE program. The software I develop for the IR sensor works without any problems. I can disable the IR sensor and control the motor remotely with the ESP8266_Standalon included in the examples of the Blynk library. The problem occurs when I combine these two codes. IR sensor is working. But I can’t control the motor from the Blynk app. By the way, I am using L293D as motor driver. I added 2 buttons from the Blynk application and with these buttons I can control the motor driver and therefore the motor. Please help me about this issue. I share the code below;
#define tsop 12
#define led 4
#define selenoidIn_1 13
#define selenoidIn_2 15
#define irLed 14
char auth[] = "lvGvhHsebiilIOMZXuhCrVx5CcoEehs_";
char ssid[] = "VsFuar";
char pass[] = "Valfsel78!";
int tsop_value;
int count = 0;
int rightTime = 0;
  pinMode(tsop, INPUT);
  pinMode(led, OUTPUT);
  pinMode(selenoidIn_1, OUTPUT);
  pinMode(selenoidIn_2, OUTPUT);
  digitalWrite(led, LOW);
  analogWriteFreq(40000);
  Fotosel();
void Fotosel()
  analogWrite(irLed, 614.4);
  tsop_value = digitalRead(tsop);
  if (tsop_value == 0 && count == 0)
    for (int i = 0; i < 1; i++)
      rightTime++;
      delay(300);
    if (tsop_value == 0 && rightTime != 0)
      digitalWrite(led, HIGH);
      delay(100);
      digitalWrite(selenoidIn_1, HIGH);
      digitalWrite(selenoidIn_2, LOW);
      digitalWrite(selenoidIn_1, LOW);
      count++;
    else if (tsop_value == 1)
      delay(100);
      rightTime = 0;
  else if (tsop_value == 0 && count == 1)
  else if (tsop_value == 1 && count == 1)
    for (int j = 0; j < 1; j++)
      rightTime++;
      delay(300);
    if (tsop_value == 1 && rightTime != 0)
      delay(100);
      digitalWrite(selenoidIn_2,HIGH);
      delay(12);
      digitalWrite(selenoidIn_2,LOW);
      count++;
    else if (tsop_value == 0)
      delay(100);
      rightTime = 0;
    count = 0;
@Atahan please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code.
