iOS app crashes when I try to delete notify widget from project
Either drag and drop it to the top, or press the Delete button in the notifications setting screen. The app closes without deleting the widget. When I logon again it’s still there
Could you please remove dashboard with those widget and create again and check if issue reproducible? It could be back compatibility issue.
yes, reproducible. opened a new project and just added the notify widget. if you want to delete it the app crashes
