iOS 8.1 bug
Been using Blynk for a few weeks now on my iPhone 6 Plus. The app has 2 buttons and 3 virtual LEDs. One of them is used as a heartbeat. Steps:
  • App opens for first time and works fine.
  • Phone goes to sleep after 2 mins.
  • When waking phone, the heartbeat LED is frozen in the ON position.
  • However, buttons still work. Only after I click one of the buttons does the heartbeat LED start to flash again.
Hi, please try latest app and tell us if problem remains.
Just tried and the issue is still there.
Any update on this guys? This is an important feature for my app as its the only way i can tell if my cc3000 is still up.
Quick update to confirm that the latest version of Blynk still has issues with status updates for widgets. For example, the “Status” button should blink on/off every second. Here it is frozen in the “on” state. The only way the app refreshes itself is when I first send a command to my Duino by touching a button or other widget. For example, moving one of the sliders is enough to kick it back to life, then the Status LED starts to blink. This affects all elements (for example, the PWD OK button should be off and all the sliders reset to 0’s by the sketch every 30 seconds - when I re-open it everything is the same way I left it minutes or hours later. In short, Blynk does not appear to properly re-establish comms and receiving updates from the Duino when it is re-opened.
I would be nice to get a response on this issue as it puts a damper on getting accurate results for projects.
@deejayspinz
I’m not able to reproduce. Is it possible to share minimum snippet of code for reproducing?
Here’s the entire sketch. You can simply re-create the issue by having a ‘hearbeat’ blink run every second and perform a Blynk.virtualWrite to a button tagged in the app:
    // Garage 2x Door Monitor and Fingerprint Opener
// Dave Astolfo www.plastibots.com
// Uses Blynk to process and display info over net from IOS/Android
// Uses Adafruit CC3000 breakout board for WiFi comms
// Uses Optiboot Nano bootloader (use Arduino v1.0.5 me)
// Uses watchdog timer due to issue with either Nano or CC3000 crashing - forces restart
// ********  Must select board:  [Optiboot] Arduino Duemilaove or Nano w/Atmega328 **********
#include <avr/wdt.h>         // required for watchdog timer
#include "FPS_GT511C3.h" //the fps (fingerprint scanner) library
//#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
// These are the interrupt and control pins for СС3000
#define ADAFRUIT_CC3000_IRQ   3
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
#include <Adafruit_CC3000.h>
#include <BlynkSimpleCC3000.h>
FPS_GT511C3 fps(2, 4); //RX, TX
const int door1ClosePin = 6;
const int door2ClosePin = 7;
const int door1LimitPin = A0;
const int door2LimitPin = A1;
const int OKLedPin = A5;
const int NotOKLedPin = A4;
const int doorStatLEDPin = 8;
const int delayVal = 100; //in milliseconds
int i = 0;
int doorState = 0;  //value
int d1S, d2S, d1LimVal, d2LimVal;
boolean door_p1, door_p2, door_p3, door_p4;  //bits for door 1 pwd
unsigned long pwdEntryStartTime = 0;
long interval = 30000;  //30 second grace period to retain password to allow opening of doors.
// You should get Auth Token in the Blynk App. Go to the Project Settings (nut icon).
char auth[] = "authcodehere";
  //Serial.begin(9600);  //for debugging - disable once live.
  pinMode(OKLedPin, OUTPUT);
  pinMode(NotOKLedPin, OUTPUT);
  pinMode(doorStatLEDPin, OUTPUT);
  pinMode(door1ClosePin, OUTPUT);
  pinMode(door2ClosePin, OUTPUT);
  pinMode(door1LimitPin, INPUT);
  pinMode(door2LimitPin, INPUT);
  fps.Open();
  fps.SetLED(true); //the fps LED
  fps.UseSerialDebug = false; //set to true for fps debugging through serial
  blink(OKLedPin, 1000, 1);
  Blynk.begin(auth, "SSID", "PASSCODE", WLAN_SEC_WPA2);
  blink(OKLedPin, 500, 3);
  wdt_enable(WDTO_8S);   //turns on watchdog timer with 8 second countdoor.  Sketch requires wtd_reset() to reset this, else a reboot is forced
  wdt_reset();  //reset as it goes through each loop - necessary to ensure the watchdog timer does not reset the Duino when it's working fine.
  if (!cc3000.checkConnected())
    wdt_reset(); //reset the watchdog timer in any normal op that may take time.
  Blynk.run();                //start polling the system and reporting to the Blynk app.
  Blynk.virtualWrite(4, 1);   //sends a heartbeat to the Blynk app.
  // Only want to send / check door state values every 0.5s (500ms) seconds.  Based on the delay value set in the main loop
  // this takes care of it without using a timer - this also does not slow down the main loop
  i++;
  if (i == (1000 / delayVal) - 1)
   Blynk.virtualWrite(4, 0);
   checkDoorState();
   i = 0;
   blink(OKLedPin, 100, 1);
  //end timing a door state check
  //scan and identify the finger when one is put on it
  chkForFingerPrint();
  delay(delayVal);
//future enhancement - allow for enrolling new fingerprints
void Enroll()
void chkForFingerPrint()
	if (fps.IsPressFinger())
                wdt_reset();	//reset the watchdog timer for any normal op that may take time.
                fps.CaptureFinger(false);
		int id = fps.Identify1_N();
		if (id < 200)
			//Serial.print("Verified ID:");
			//Serial.println(id);
                        blink(OKLedPin, 100, 2);
                        Action(1);   //Open the Garage door
			//Serial.println("Finger not found");
                        blink(NotOKLedPin, 100, 3);
void blink(int whichLED, int dly, int numTimes)
  for (int i = 1; i<=numTimes; i++){
    digitalWrite(whichLED, HIGH);
    delay(dly);
    digitalWrite(whichLED, LOW);
    delay(100);
void checkDoorState()
  //the master controller will send values to this analog pin when the doors are open. When closed, the value will be 0
  //will need to have 4 door state values.
  // door 1 = open, door 1 & 2 open, door 2 open.  all doors closed
  d1LimVal = analogRead(door1LimitPin);
  d2LimVal = analogRead(door2LimitPin);
  //Serial.print("Limit1Val:  ");
  //Serial.print(d1LimVal);
  //Serial.print("   Limit2Val:  ");
  //Serial.println(d2LimVal);
  if ((d1LimVal >= 1000) && (d2LimVal >= 1000))  //both door limit switches are closed. 1023
    d1S = 1;
    d2S = 1;
    blink(NotOKLedPin, 100, 1);
    msgOut(doorStatLEDPin, 1);
  else if ((d1LimVal >= 1000) && (d2LimVal < 50))
    d1S = 1;
    d2S = 0;
  else if ((d1LimVal < 50) && (d2LimVal >= 1000))
    d1S = 0;
    d2S = 1;
    d1S = 0;
    d2S = 0;
    msgOut(doorStatLEDPin, 0);
  Blynk.virtualWrite(1, d1S);  //sends the state of Garage door 1 - if 1, then open
  Blynk.virtualWrite(3, d2S);  // sends the state of Garage door 2 - if 1, then open
  //reset the timer values used for pwd entry
  if (millis() - pwdEntryStartTime > interval)
    door_p1 = false, door_p2 = false, door_p3 = false, door_p4 = false;
    //reset the sliders in the Blynk app - do this after the interval time has elapsed.
	Blynk.virtualWrite(9, 0);  //pwd is no longer valid - update LED to OFF state
    Blynk.virtualWrite(5, 0);  //reset the pwd sliders to 0
    Blynk.virtualWrite(6, 0);  //reset the pwd sliders to 0
    Blynk.virtualWrite(7, 0);  //reset the pwd sliders to 0
    Blynk.virtualWrite(8, 0);  //reset the pwd sliders to 0
  if (door_p1 && door_p2 && door_p3 && door_p4)
    Blynk.virtualWrite(9, 1);  //pwd is correct - illuminate LED
    Blynk.virtualWrite(9, 0);  //pwd is no longer correct - illuminate LED
// a state of 0 means one or more doors open. Else, 1 means all good
// Uses AnalogRead on slave ATTiny85 to determine which state was sent and blink either a red or green LED.
void msgOut(int statLED, int state)
 if (state == 1)
   //red LED - one or more doors are open
   //analogWrite(statLED, 255);
   digitalWrite(statLED, HIGH);
   //green LED - everything good
   //analogWrite(statLED, 0);
   digitalWrite(statLED, LOW);
// DOOR 1
// This function will be called every time when the Blynk App writes value to Virtual Pin 0  - This will be when Door 1 is clicked to init closing the door
//Note - when App Virtual Button is set as Push - it will send 2 commands, first HIGH, then LOW one right afer each other.
BLYNK_WRITE(0)
  //BLYNK_LOG("Got a value: %s", param.asStr());
  // You can also use: asInt() and asDouble()
  //digitalWrite(OKLedPin, param.asInt());
  //label = 1;  //tell it to act on door 2
  //Serial.print("Param:  ");
  //Serial.println(param.asInt());
  if (param.asInt() == 1 && (door_p1 && door_p2 && door_p3 && door_p4))  //passcode must be true.  if so and clicks button open door.
    if (millis() - pwdEntryStartTime < interval)
      Action(1);   //send command to master to open/close door.
    //door_p1 = false, door_p2 = false, door_p3 = false, door_p4 = false;
// DOOR 2
// This function will be called every time when the Blynk App writes value to Virtual Pin 2  - This will be when Door 2 is clicked to init closing the door
BLYNK_WRITE(2)
     Action(2);   //send command to master to open/close door.
// Door 1 passcode values - uses sliders in Blynk
BLYNK_WRITE(5)
  pwdEntryStartTime = millis();  //start the timer
  //Blynk.virtualWrite(9, 1);  //illuminate the led to indicate pwd entry is valid.
  if (param.asInt() == 1) {  door_p1 = true; } else  { door_p1 = false; }
BLYNK_WRITE(6)
  if (param.asInt() == 1) {  door_p2 = true; } else  {    door_p2 = false; }
BLYNK_WRITE(7)
  if (param.asInt() == 1) {  door_p3 = true; } else  {    door_p3 = false; }
BLYNK_WRITE(8)
  if (param.asInt() == 1) {  door_p4 = true; } else  {    door_p4 = false; }
void Action(int label)
  //digitalWrite(OKLedPin, HIGH);
  if(label == 1)
    digitalWrite(door1ClosePin, HIGH);delay(200);digitalWrite(door1ClosePin,LOW);
  if(label == 2)
    digitalWrite(door2ClosePin, HIGH); delay(200); digitalWrite(door2ClosePin, LOW);
  delay(500);
  //digitalWrite(OKLedPin, LOW);
