Invalid HW cmd: 1018039319
I just created a sketch from
https://examples.blynk.cc/?board=Arduino%20Mega%202560&shield=HC05%20or%20HC06&example=Widgets%2FJoystickTwoAxis&auth=21d19d7c7f8245c9ae9b00f9a2c8ebd1
And didn’t change a thing from that forum but I’m still getting the error in the serial monitor-
the whole text in the serial monitor includes-
[169346] Connecting...
[169549] Ready (ping: 85ms).
[183574] Invalid HW cmd: 1018039319
And just repeats those 3 lines of text
the whole code consists of-
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Note: This only works on Android!
        iOS does not support Bluetooth 2.0 Serial Port Profile
        You may need to pair the module with your smartphone
        via Bluetooth settings. Default pairing password is 1234
  NOTE: Bluetooth support is in beta!
  You can receive x and y coords for joystick movement within App.
  App project setup:
    Two Axis Joystick on V1 in MERGE output mode.
    MERGE mode means device will receive both x and y within 1 message
char auth[] = "21d19d7c7f8245c9ae9b00f9a2c8ebd1";
SoftwareSerial SerialBLE(10, 11); // RX, TX
BLYNK_WRITE(V1) {
  int x = param[0].asInt();
  int y = param[1].asInt();
  // Do something with x and y
  Serial.print("X = ");
  Serial.print(x);
  Serial.print("; Y = ");
  Serial.println(y);
  SerialBLE.begin(9600);
  Blynk.begin(SerialBLE, auth);
Im using bluetooth HC05 and an arduino Mega and attempting to use the joystick to control a H-Bridge for the wheels (haven’t added that yet)
May not be related to your error, which I suspect happens whenever you move the joystick?.. but with the Mega, I recommend you use one of its three auxiliary Hardware serial ports (instead of SoftSerial) for your BLE connection, for faster and more reliable connections.
https://www.arduino.cc/en/Tutorial/MultiSerialMega
Switch to that and see if it helps.
