Invalid Auth Tokennn
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
```#define BLYNK_TEMPLATE_ID "TMPLtKOX46Fx"
#define BLYNK_DEVICE_NAME "WaterLEVEL DISPLAY"
#define BLYNK_PRINT SwSerial
char auth[] = "TgnkiimNzysFh345mZgtkqgckay4xAqc";
WidgetLCD lcd(V1);
long duration, distance;
int trig =4;
int eco =5;
void myTimerEvent()
  int data = analogRead(A2)*(3.20/1023.0)*100.0;
  Blynk.virtualWrite(V5, data);
BLYNK_WRITE(V2)
  int pinValue = param.asInt();
  digitalWrite(2, pinValue);
  digitalWrite(3, pinValue);
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
  pinMode(trig, OUTPUT);
  pinMode(eco, INPUT);
  lcd.clear();
  lcd.print(0, 0, "distance CM");
  lcd.clear();
  digitalWrite(trig, LOW);
  delayMicroseconds(3);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  digitalWrite(trig,LOW);
  duration = pulseIn(eco, HIGH);
  distance = (duration/2) /588.10;
  lcd.print(7,1, distance);
Have you edited the USB script to use blynk.cloud as the server rather than blynk-cloud.com ?
