Invalid auth token too
Hi All
I would like to have your help because I do not understand where my problem is with my code. I always have this Invalid auth token error message.
Could you guide me?
I Had already test my token and i’ts works !
http://blynk-cloud.com/Lbp1kDGsYcbwVhlR3KFCUFHoTBexs1VS/project
thank you all
My Code:
      This sketch shows how to write values to Virtual Pins
      NOTE:
      BlynkTimer provides SimpleTimer functionality:
        http://playground.arduino.cc/Code/SimpleTimer
      App project setup:
        Value Display widget attached to Virtual Pin V5
    #define BLYNK_TEMPLATE_ID           "TMPLCK0iTFzn"
    #define BLYNK_DEVICE_NAME           "phy"
    #define BLYNK_AUTH_TOKEN            "Lbp1kDGsYcbwVhlR3KFCUFHoTBexs1VS"
    char ssid[] = "wifi***";
    char pass[] = "******";
    void myTimerEvent()
      //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
      //Blynk.begin(auth, ssid, pass, IPAddress(192,168,,100), 8080);
You are using a Blynk Legacy token, but these two lines force a connection to the Blynk IoT servers.
Why do you have a template ID with Blynk Legacy?
indeed it works much better.
I did not understand the difference, thank you
