Invalid auth token on blynk 2.0
i cant connect to blynk cloud somehow,i already double check the aut code
[56276] Connected to WiFi
[56276] IP: 192.168.43.110
[56276]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on ESP8266
[56357] Connecting to blynk-cloud.com:80
[57239] Invalid auth token```
here the code i use
```#define BLYNK_TEMPLATE_ID "TMPLwP4_Ylha"
#define BLYNK_DEVICE_NAME "es"
#define BLYNK_AUTH_TOKEN "t9fudHWdRR2jSIZale0HA-Lbytd6O8en"
char auth[] = "t9fudHWdRR2jSIZale0HA-Lbytd6O8en";
char ssid[] = "POCOPHONE";
char pass[] = "12345678";
// X Stepper Motor
int XstepPin = D1;
int XdirPin  = D2;
int limitx = 200; // X stepper motor limit
int speedx = 500;
// Y Stepper Motor
int YstepPin = D3;
int YdirPin  = D4;
int speedy = 500;
int Movey = 512; // value from blynk joystick "default value"
// Manual control X stepper motor
int vresistor = A0;
int vrdata = 0;
int pinValue1;
int pinValue2;
int pinValue3;
int pinValue4;
int firstVal, secondVal,thirdVal; // sensors
// This function sends Arduino's up time every second to Virtual Pin (1).
void myTimerEvent()
  Blynk.virtualWrite(V1, millis() / 1000);
  pinMode(XstepPin,OUTPUT);
  pinMode(XdirPin, OUTPUT);
    pinMode(YstepPin,OUTPUT);
  pinMode(YdirPin, OUTPUT);
  pinMode(vresistor, INPUT);
  timer.setInterval(4000L, StepperMotor);
    timer.setInterval(300L, StepperMotorY);
// From Blynk application to Nodemcu ESP8266
// in Blynk app writes values to the Virtual Pin V2
BLYNK_WRITE(V2) // X stepper Motor limits
   pinValue1 = param.asInt(); // assigning incoming value from pin V2 to a variable
   limitx = pinValue1;
BLYNK_WRITE(V3) // X stepper Motor Speed
   pinValue2 = param.asInt();
   speedx = pinValue2;
BLYNK_WRITE(V5) // Y Stepper motor control
   pinValue3 = param.asInt();
   Movey = pinValue3;
void StepperMotor()
  if( digitalRead(D6) == 1 )
   digitalWrite(XdirPin,HIGH); // Enables the motor to move in a particular direction
 for(int x = 0; x < limitx; x++) {
 digitalWrite(XstepPin,HIGH);
 delayMicroseconds(speedx);
 digitalWrite(XstepPin,LOW);
 delay(500); // half second delay
 digitalWrite(XdirPin,LOW); //Changes the rotations direction
 delay(500);
void StepperMotorY()
    if( digitalRead(D6) == 0 )
    vrdata = analogRead(vresistor);
    if ( vrdata < 100 )
        if ( vrdata > 900 )
  if ( Movey > 512 )
 digitalWrite(YdirPin,HIGH); // Enables the motor to move in a particular direction
 digitalWrite(YstepPin,HIGH);
 delayMicroseconds(speedy);
 digitalWrite(YstepPin,LOW);
    if ( Movey < 512 )
   digitalWrite(YdirPin,LOW); // Enables the motor to move in a particular direction
Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Please do the same for your serial monitor text.
You should update the library to the latest version (1.1.0).
it worked now after update, thanks john
