hello everyone
i am facing a problem and i need your help
i was using the old blynk app and everything was ok when i upgrade the code with the
new parametres i cant connect to the server, i take invalid auth token .
Blynk Flow Sensor Water Meter- Calculates Total Water Consumption.
Source: https://github.com/pkarun/Blynk-Flow-Sensor-Water-Meter
#define BLYNK_PRINT Serial // Uncomment for debugging
#define BLYNK_TEMPLATE_ID "TMPLTeFN6BIo"
#define BLYNK_DEVICE_NAME "water control tserapi"
#include "settings.h"
#include "secret.h" // <<--- UNCOMMENT this before you use and change values on config.h tab
//#include "my_secret.h" // <<--- COMMENT-OUT or REMOVE this line before you use. This is my personal settings.
#include <ESP8266mDNS.h> // For OTA with ESP8266
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
volatile long pulseCount = 0;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
float totalLitres;
float totalLitresold;
unsigned long oldTime;
BLYNK_CONNECTED() { // runs once at device startup, once connected to server.
Blynk.syncVirtual(VPIN_TOTAL_LITERS); //gets last know value of V1 virtual pin
// Restores last know value of V1 virtual pin which we got it from blynk server
BLYNK_WRITE(VPIN_TOTAL_LITERS)
totalLitresold = param.asFloat();
BLYNK_WRITE(VPIN_RESET) { // reset all data with button in PUSH mode on virtual pin V4
int resetdata = param.asInt();
if (resetdata == 0) {
Serial.println("Clearing Data");
Blynk.virtualWrite(VPIN_TOTAL_LITERS, 0);
Blynk.virtualWrite(VPIN_FLOW_RATE, 0);
flowRate = 0;
flowMilliLitres = 0;
totalMilliLitres = 0;
totalLitres = 0;
totalLitresold = 0;
void pulseCounter()
pulseCount++;
void flow()
if ((millis() - oldTime) > 1000) // Only process counters once per second
detachInterrupt(PULSE_PIN);
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / FLOW_CALIBRATION;
oldTime = millis();
flowMilliLitres = (flowRate / 60) * 1000;
totalMilliLitres += flowMilliLitres;
totalLitres = totalLitresold + totalMilliLitres * 0.001;
unsigned int frac;
// Print the flow rate for this second in liters / minute
Serial.print("flowrate: ");
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("."); // Print the decimal point
frac = (flowRate - int(flowRate)) * 10; // Determine the fractional part. The 10 multiplier gives us 1 decimal place.
Serial.print(frac, DEC) ; // Print the fractional part of the variable
Serial.print("L/min");
Serial.print(" Current Liquid Flowing: "); // Print the number of liters flowed in this second
Serial.print(flowMilliLitres);
Serial.print("mL/Sec");
Serial.print(" Output Liquid Quantity: "); // Print the cumulative total of liters flowed since starting
Serial.print(totalLitres);
Serial.println("L");
pulseCount = 0; // Reset the pulse counter so we can start incrementing again
attachInterrupt(PULSE_PIN, pulseCounter, FALLING); // Enable the interrupt again now that we've finished sending output
void sendtoBlynk() // In this function we are sending values to blynk server
Blynk.virtualWrite(VPIN_TOTAL_LITERS, totalLitres); // Total water consumption in liters (L)
Blynk.virtualWrite(VPIN_FLOW_RATE, flowRate); // Displays the flow rate for this second in liters / minute (L/min)
// Blynk.virtualWrite(VPIN_FLOW_RATE, flowMilliLitres); // Displays the number of liters flowed in second (mL/Sec)
Serial.begin(57600);
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS);
ArduinoOTA.setHostname(OTA_HOSTNAME); // For OTA - Use your own device identifying name
ArduinoOTA.begin(); // For OTA
pulseCount = 0;
flowRate = 0.0;
oldTime = 0;
totalLitresold = 0;
pinMode(PULSE_PIN, INPUT); // Initialization of the variable "PULSE_PIN" as INPUT (D2 pin)
timer.setInterval(10000L, sendtoBlynk); // send values blynk server every 10 sec
ArduinoOTA.handle(); // For OTA
flow();
the code isnt mine i just used it
thank you
