.All,
Need help, I am using ESP32 to run blynk client & I am getting below error.
–Serial Montior log ----
15:36:58.364 -> [2638] Connected to WiFi
15:36:58.364 -> [2638] IP: 192.168.1.96
15:36:58.411 -> [2638]
15:36:58.411 -> ___ __ __
15:36:58.458 -> / _ )/ /_ _____ / /__
15:36:58.458 -> / _ / / // / _ \/ '_/
15:36:58.504 -> /____/_/\_, /_//_/_/\_\
15:36:58.504 -> /___/ v1.0.0 on ESP32
15:36:58.551 ->
15:36:58.551 -> [2711] Connecting to blynk-cloud.com:80
15:36:58.692 -> [2975] Invalid auth token
http://twitter.com/blynk_app
This example runs directly on ESP32 chip.
Note: This requires ESP32 support package:
https://github.com/espressif/arduino-esp32
Please be sure to select the right ESP32 module
in the Tools -> Board menu!
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define BLYNK_TEMPLATE_ID "TMPLqbkhOY-9"
#define BLYNK_DEVICE_NAME "Device1 F43EA"
#define BLYNK_HEARTBEAT 60
char auth[] = "7tPNAfmunMVm4ZtElN_wVV8mFmVS5k-b";
char ssid[] = "*************";
char pass[] = "**********";
uint8_t analogPin = 34; // Pin used to read data from GPIO34 ADC_CH6.
BlynkTimer timer; // Announcing the timer
timer.setInterval(1000L, sensorDataSend); //timer will run every sec
timer.run(); // run timer every second
void sensorDataSend()
int sensorValue=0;
sensorValue = analogRead(analogPin); // reading sensor from analog pin
Blynk.virtualWrite(V1, sensorValue); // sending sensor value to Blynk app
