I am fairly new to Blynk and am working on a mini home automation project (sprinkler system). I have written my program on a Wemos D1 Mini and I have created my HMI on Blynk on my Android phone.
Everything seems to work perfectly fine, except that intermittently (very often), the connection of the Wemos to the Blynk server gets lost and takes a long time to reconnect, only to get dropped again later.
I am not writing my code in the Loop; my code runs in a Timer function every 500ms, so I don’t think it it overcrowding the server (?).
I have pasted all my code here. Would someone be able to tell me what stupid mistake I am making? Sorry for the long code…
Note: The Relay library is one that I created. I am not including the code here for brevity and because I don’t think it is relevant. If you need to see it let me know and I will post it.
Thanks!!
// Defines & Includes
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <ESP8266Ping.h>
#include <Relay.h>
// Variable Declaration
char auth[] = ****;
Relay ValveRelay1, ValveRelay2, ValveRelay3;
BlynkTimer TC1_Process;
int scheduler = 0;
const int TC1_Time = 500;
int hmi_LED = 0;
int V1Int, V2Int, V3Int, V4Int, V5Int, V6Int, V7Int, V8Int, V21Int, V22Int, V23Int;
//float V11Real, V12Real, V13Real, V14Real;
float remaining1, remaining2, remaining3;
int dxAutoSequence, diTRIGGER, dxRESET, dxSKIP, dxSTOPALLVALVES, ixTIMERLIMIT_min, ixTIMERLIMIT_ms;
int hmi_TIME1, hmi_TIME2, hmi_TIME3, hmi_STATE1, hmi_STATE2, hmi_STATE3;
int hmi_CloseVLV1, hmi_CloseVLV2, hmi_CloseVLV3;
int hmi_OpenVLV1, hmi_OpenVLV2, hmi_OpenVLV3;
int I33VLV1, I33VLV2, I33VLV3;
//float aiTIMERSETTING;
// PERIODIC ROUTINE
void TC1(){ // 500ms
// ---------- INPUTS -----------------------------------------------
I33VLV1 = digitalRead(D0);
I33VLV2 = digitalRead(D5);
I33VLV3 = digitalRead(D6);
diTRIGGER = V8Int;
dxSTOPALLVALVES = V6Int;
hmi_OpenVLV1 = V1Int;
hmi_OpenVLV2 = V2Int;
hmi_OpenVLV3 = V3Int;
hmi_CloseVLV1 = V21Int;
hmi_CloseVLV2 = V22Int;
hmi_CloseVLV3 = V23Int;
ixTIMERLIMIT_min = V7Int;
ixTIMERLIMIT_ms = 1000*60*ixTIMERLIMIT_min;
// ---------- CORE -------------------------------------------------
dxAutoSequence = (diTRIGGER || dxAutoSequence) && !ValveRelay3.FallingEdge && !dxSTOPALLVALVES;
ValveRelay1.Run();
ValveRelay2.Run();
ValveRelay3.Run();
ValveRelay1.TimedActivation(hmi_OpenVLV1 || diTRIGGER, hmi_CloseVLV1 || dxSTOPALLVALVES, ixTIMERLIMIT_ms);
hmi_TIME1 = DivIntProt(100 * ValveRelay1.CurrentTimerValue, ixTIMERLIMIT_ms);
Serial.println(D0);
Serial.println(hmi_OpenVLV1);
Serial.println(hmi_CloseVLV1);
Serial.println(ixTIMERLIMIT_ms);
Serial.println(ValveRelay1.State);
Serial.println(I33VLV1);
Serial.println(ValveRelay1.CurrentTimerValue);
Serial.println("-");
Serial.println(millis());
ValveRelay2.TimedActivation(hmi_OpenVLV2 || (dxAutoSequence && (ValveRelay1.FallingEdge)), hmi_CloseVLV2 || dxSTOPALLVALVES, ixTIMERLIMIT_ms);
hmi_TIME2 = DivIntProt(100 * ValveRelay2.CurrentTimerValue, ixTIMERLIMIT_ms);
ValveRelay3.TimedActivation(hmi_OpenVLV3 || (dxAutoSequence && (ValveRelay2.FallingEdge)), hmi_CloseVLV3 || dxSTOPALLVALVES, ixTIMERLIMIT_ms);
hmi_TIME3 = DivIntProt(100 * ValveRelay3.CurrentTimerValue, ixTIMERLIMIT_ms);
remaining1 = ValveRelay1.RemainingTime/60000.0;
remaining2 = ValveRelay2.RemainingTime/60000.0;
remaining3 = ValveRelay3.RemainingTime/60000.0;
hmi_LED = 255 - hmi_LED;
hmi_STATE1 = (I33VLV1 == LOW) ? 0 : 255;
hmi_STATE2 = (I33VLV2 == LOW) ? 0 : 255;
hmi_STATE3 = (I33VLV3 == LOW) ? 0 : 255;
// ---------- OUTPUTS ----------------------------------------------
Blynk.virtualWrite(V5, hmi_LED);
Blynk.virtualWrite(V31, hmi_TIME1);
Blynk.virtualWrite(V32, hmi_TIME2);
Blynk.virtualWrite(V33, hmi_TIME3);
Blynk.virtualWrite(V41, remaining1);
Blynk.virtualWrite(V42, remaining2);
Blynk.virtualWrite(V43, remaining3);
Blynk.virtualWrite(V51, hmi_STATE1);
Blynk.virtualWrite(V52, hmi_STATE2);
Blynk.virtualWrite(V53, hmi_STATE3);
digitalWrite(D1, HIGH);
ValveRelay1.UpdateOutput();
ValveRelay2.UpdateOutput();
ValveRelay3.UpdateOutput();
// SETUP
ValveRelay1.SetPin(D0);
ValveRelay2.SetPin(D5);
ValveRelay3.SetPin(D6);
ValveRelay1.UpdateRate = TC1_Time;
ValveRelay2.UpdateRate = TC1_Time;
ValveRelay3.UpdateRate = TC1_Time;
ValveRelay1.AutoOutput = 0;
ValveRelay2.AutoOutput = 0;
ValveRelay3.AutoOutput = 0;
// Pin initialization
pinMode(D1, OUTPUT); // Status LED
pinMode(D0, OUTPUT); // Valve 1
pinMode(D5, OUTPUT); // Valve 2
pinMode(D6, OUTPUT); // Valve 3
digitalWrite(D1, HIGH); // Status LED
digitalWrite(D0, LOW); // Valve 1
digitalWrite(D5, LOW); // Valve 2
digitalWrite(D6, LOW); // Valve 3
dxSTOPALLVALVES = 0;
// Periodic Routine Setup
TC1_Process.setInterval(TC1_Time, TC1);
// WiFi Setup and Connection
WiFiManager wifiManager;
wifiManager.autoConnect("AutoConnectAP");
Serial.println("Connected!");
WiFiManagerParameter custom_blynk_token("Blynk", "blynk token", auth, 33);
wifiManager.addParameter(&custom_blynk_token);
wifiManager.autoConnect("Blynk");
Blynk.config(custom_blynk_token.getValue());
// USER-DEFINED FUNCTIONS
int DivIntProt(int in1, int in2)
if (in2 == 0)
return 0;
return (in1 / in2);
// LOOP
TC1_Process.run(); // Initiates BlynkTimer
// BLYNK SYNC ALL
bool isFirstConnect = true; // Keep this flag not to re-sync on every reconnection
BLYNK_CONNECTED() // This function will run every time Blynk initial connection is established
if (isFirstConnect) {
Blynk.syncAll();
isFirstConnect = false;
// BLYNK INPUTS
BLYNK_WRITE(V1)
int value = param.asInt(); // Get value as integer
V1Int = value;
BLYNK_WRITE(V2)
V2Int = value;
BLYNK_WRITE(V3)
V3Int = value;
BLYNK_WRITE(V4)
V4Int = value;
BLYNK_WRITE(V5)
V5Int = value;
BLYNK_WRITE(V6)
V6Int = value;
BLYNK_WRITE(V7)
V7Int = value;
BLYNK_WRITE(V8)
V8Int = value;
BLYNK_WRITE(V21)
V21Int = value;
BLYNK_WRITE(V22)
V22Int = value;
BLYNK_WRITE(V23)
V23Int = value;
// WIFI: configModeCallback
// Gets called when WiFiManager enters configuration mode
void configModeCallback (WiFiManager *myWiFiManager)
Serial.println("Entered config mode");
Serial.println(WiFi.softAPIP());
Serial.println(myWiFiManager->getConfigPortalSSID());
