Hey guys,
I just got my ESP8266. I set up the DHT11 Sensor and got the Code ready. But now i want to have an LED Displaying the Status of the Sensor example Sensor is not working set the Led to Red. But unfortunately it´s not working properly.
Sry for my bad english but it´s not my main language.
Your Help would be appreciated.
My Code:
* This example shows how value can be pushed from Arduino to
* the Blynk App.
* WARNING :
* For this example you'll need SimpleTimer library:
* https://github.com/jfturcot/SimpleTimer
* and Adafruit DHT sensor library:
* https://github.com/adafruit/DHT-sensor-library
* App project setup:
* Value Display widget attached to V5
* Value Display widget attached to V6
#include <DHT.h>
char auth[] = "f82eedd4thatsnotmyauth:)4ccf35e3d";
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxxxxx";
WidgetLED led1(V1);
bool ledStatus = false;
#define BLYNK_GREEN "#23C48E"
#define BLYNK_RED "#D3435C"
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
void blinkLedWidget()
led1.setColor(BLYNK_RED);
Serial.println("Led on V1: red");
ledStatus = true;
led1.setColor(BLYNK_GREEN);
Serial.println("LED on V1: green");
ledStatus = false;
dht.begin();
And I can’t find any call to the blinkLedWidget() function.
You must insert another timer to do it:
But you could just use the same sendSensor function to check the availability of the sensor data and change the led color accordingly
@J4ck I may be mistaken, but I do not see your blinkLedWidget() function being called anywhere. You need to add a timer, timer.setInterval(1000L, blinkLedWidget);
Or, you could eliminate this blinkLedWidget() function and just add the color changing command to the first IF statement, since it is the same conditions, if (isnan(h) || isnan(t)).
void sendSensor(){
Blynk.setProperty(V1, "color", BLYNK_RED);
ledStatus = true;
Blynk.setProperty(V1, "color", BLYNK_GREEN);
Serial.println("Received reading from DHT sensor!");
ledStatus = false;
Yes you will need to include the #define for the colors you wish to use.
As for the timer.setInterval(1000L, blinkLedWidget); it should go right before or after timer.setInterval(1000L, blinkLedWidget); in your setup function.
It´s kinda working now, but it´s switching between Received Reading and Failed to Read
it displays this in serial monitor
Failed to read from DHT sensor!
Led on V1: red
Led on V1: red
LED on V1: green
Everything is working now but still switching between states some times it stays then it switches to failed again can´t see any patterns
* the Blynk App.
* WARNING :
#include <DHT.h>
WidgetLED led1(V1);
void sendSensor(){
led1.on(); //turn on led
ledStatus = true;
ledStatus = false;
dht.begin();
