So you’re saying I’m not connecting right? I did managed to send values to the blynk app tough… so I know I did made a connection at some point… (this is a new project by the way, I’m having a working project | a beer brewery | on another arduino and it works just fine. I just never had to send data back to the hardware before…)
I’ve tried it before when I came across this link ([SOLVED] Blynk app says "device is offline" - #3 by sanjaysy), alas, did not work… tried it again tough just to try to pinpoint to the source of the problem with you all on this tread. Resulting serial:
rl��r��c�n�����p�|����x��ǒ��p�nn��;�n����e�b�cl`e$`e�rl��r��c�n�����p�|����x��ǒ��p�nn��;�n����e�b�cl`e$`e�p�n�������l�����b�n��n�$��b��>~�n�����l`e���#�n�rnr���;����{r�ےn��b��`eĞ�l�����x��r��n�b�[43] Connecting to Tuypgroup
[3544] Connected to WiFi
[3544] IP: 192.168.178.179
[3544]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.2 on Arduino
[3550] Connecting to blynk-cloud.com:80
[3645]�rl��r��c�n�����p�|����x��ǒ��p�nn��;�n�����b�$ rrp�n�������l�����b�n��n�$��b��<~�n��Ì�l`e���#�n�rnr���;����sr�ےn��b��`eĞ�l�����x��r��n�b�[43] Connecting to Tuypgroup
[1543] Connected to WiFi
[1544] IP: 192.168.178.179
[1544]
___ __ __
[1550] Connecting to blynk-cloud.com:80
[1634]�rl��r��c�n�����p�|����p��ǒ��p�nn��;�n����e�b�$errp�n�������l�����b�n��n�$��b��>~�n�����l`e���#�n�rnr���;����{r�ےn��b��`eĞ�l�����8��r��n�b�[43] Connecting to Tuypgroup
[1543] IP: 192.168.178.179
[1543]
___ __ __
[1549] Connecting to blynk-cloud.com:80
[1641]�rl��r��c�n�����p�|����x��ǒ��p�nn��;�n����e�b�$ rrp�n�������l�����b�n��n�$��b��>~�n�����l`e���#�n�rnr���;����{r�ےn��b��`eĞ�l�����x��r��n�b�[43] Connecting to Tuypgroup
[544] Connected to WiFi
[544] IP: 192.168.178.179
[544]
___ __ __
I did move the slider, the app said “device is offline”
No, I’m not saying that. Just throwing some things out there to try. May or May not help.
I loaded your above code onto an esp I have sitting here at work. You code works as it should when I test it. So this point to an issue on your end. What it is, I am not certain.
P.S. I didn’t do the edits I suggested either, so u can disregard my previous attempt to help.
P.P.S. Having this in the loop() may cause disconnection issues. As you have this same line in the BLYNK_WRITE() function, it should print the valve to the serial monitor if it changes.
Serial.print("V15 Slider value is: ");
Serial.println(pinValue); // still should print 412
Just an update, I got a new WeMos D1 Mini WIFI with an esp-12-f integrated onto it and the code worked without problem. I still have to get it to work on a standalone esp. Now I know for sure that it is as Toro_blanco said an hardware problem and I can troubleshoot directed at that.
