Improvement of history graph
I know, there are a lot of topics about history graph. At the moment, in this widget is not very simple to read values etc etc. But I think that a small graphic improvement Can help. In order to read the newest data in the graph, It would be better if i have values of y axis in the right too. Like in the screenshot, i have trouble to read the exact value of the lines in the right side.
What do you think? :slight_smile:
Reasonable suggestion.
Is that important as I always thought graphs were a visual representation of a dataset and I would look at the data if I need to know exact values.
I think it would be easier for you to read the data if you used a better scale.
I agree with you about scale. I think that the best way to have a good and functional graph widget, is to have the possibility to tap in the graph and have various details in that point. Certainly this requires time and programming skills in Android and iOS envirorments, so the compromise, for now, is adding y axis values in the right :joy:
