BLYNK
Impossible to connect to Quickstart Devide
Hi guys,
I’m tring to lern ho w to create scketch with ***Blynk 2.0; and statring to the base i have a problem with the wifi connection with ESP32 module.
I have loaded the sketch received and the esp result connected to the wifi looking to my phone that is in router mode, but on Blynk 2.0 looks offline.
This is the sckect:
BLYNK_TEMPLATE_NAME is black, I don’t know if this can be the matter:
Thanks for the help
Raffaele
@Raffaulua Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
This is irrelevant.
Post your code, correctly formatted with triple backticks, and we’ll take a look at it.
