Image Gallery
I think you’d be better doing something like this:
  uint32_t randomNum = random(50000);
  String image_url = "http://"+local_IP+"/capture?_cb="+ (String)randomNum;
  Serial.print("Captured image data:" );
  Serial.println(image_url );
  Blynk.setProperty(V1, "urls",image_url);
Also, when you copy the url from your serial monitor and paste it into a browser, does it display the image?
If so, then does that same url display the image when you past it into the browser on your phone?
The image does not show in the Browser.
I tried my original code, and then the code you suggested. Neither one shows image in app or browser.
this is the url:
http://192.168.0.111/capture?_cb=19774
And Here is my entire code block:
#include "esp_camera.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// Select camera model
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#include "camera_pins.h"
#define PHOTO 14
#define LED 4
char auth[] = "ypyXXitKv6dL7mTJ5D0_yP_FJQb_QM5X";
const char* ssid = "network";
const char* password = "password";
String local_IP;
int count = 0;
void startCameraServer();
void takePhoto()
  digitalWrite(LED, HIGH);
  delay(200);
  digitalWrite(LED, LOW);
  pinMode(LED,OUTPUT);
  Serial.setDebugOutput(true);
  Serial.println();
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, -2); // lower the saturation
  // drop down frame size for higher initial frame rate
  s->set_framesize(s, FRAMESIZE_QVGA);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  local_IP = WiFi.localIP().toString();
  Serial.println("' to connect");
  Blynk.begin(auth, ssid, password);
  if(digitalRead(PHOTO) == HIGH){
    takePhoto();
I suspected as much.
Your takePhoto() function seems to be generating a random number between 0 and 50,000 and appending that to your base url and sending this to the serial monitor and Blynk.
But, I see no code to actually capture an image from the camera or save it with this same url
How is the capture/save process actually initiated, and how is the captured image named in your code?
I tap a button in the app.
The camera flashes each time i press the button.
That’s a very messy way to do it. You’d be much better using a virtual pin in the app and using the BLYNK_WRITE(vPin) callback to take the photo.
But, which lines of code do you think are responsible for taking the photo and saving it with your chosen filename?
takePhoto?
Trying to work on saving now.
I’m Scraping everything and starting over. lol :man_facepalming::man_shrugging:
