cactus
January 24, 2017, 9:11am
1
I’ve ran into some problems.
I can’t seem to get anything to work with my amazon echo with IFTTT.
Here is my maker stuff and the notification on alexa’s app to let me know that it was understood.
https://i.imgur.com/qnROee8.png ]
The IFTTT applet says it has ran, but my relay switch does not turn on.
Everything seems great, but why wont it work? ARRRGH!
Would appreciate some help.
proteek
January 24, 2017, 12:00pm
2
Change the URL as follows:
http://blynk-cloud.com/****your blynk token/update/D1?value=0 to switch off
OR
http://blynk-cloud.com/****your blynk token/update/D1?value=1 to switch on
Bro it works like charm for me u must be doing something wrong
Blynk url wont work instead of that u have to insert ip as i m using alexa ifttt from a long time with blynk
Small program change its
[“0”] and [“1”]
Since im using this it works for me give a try and let me know
cactus
January 24, 2017, 3:29pm
6
Where do I put the [“0”] and [“1”]?
cactus
January 24, 2017, 3:30pm
7
That doesn’t seem to work for me either.
It should be application json
Then in body
If you want to turn on [“0”]
Off [“1”]
Still problem ping me
See this it works like a charm for me
cactus
January 24, 2017, 3:46pm
11
Thats mine, my echo still says sending that to ifttt but still nothing happens.
If I open the blink app and check my pin, it is still pin D1 and it works perfectly from the app.
I’ve got to be missing something really stupid
EDIT: http://139.59.206.133/xxxxxAUTHCODE HERE/update/D1 does not work either
See iam dam sure your mistake lies in ip address u check the ip address i am 100 percent sure it would be wrong
Last thing i can suggest you make sure account you have logged in in ifttt n account in blynk both r same
cactus
January 24, 2017, 4:38pm
14
I just pop into CMD and hit : ping blynk-cloud.com for a result of 139.59.206.133 the same IP as I use in my IFTTT recipie.
cactus
January 24, 2017, 4:42pm
15
What do you mean by that?
I’ve used the same email for both the ifttt and blynk if that’s what you’re saying.
cactus
January 24, 2017, 5:07pm
16
Coming to think about it, could it have anything to do with my sketch?
char auth[] = "xxxxxx";
char ssid[] = "ethernetwifi";
char pass[] = "passwordhere";
I’m using a NodeMCU ESP-12E. And my pin to toggle my relay is pin “D0”
Also, if I paste my IFTTT web request into chrome, surely it should work too right? I mean it just says “Wrong request format.”
Hey i seriously don’t know whats wrong then i gave all suggestions i could give you may be ask dimitry
cactus
January 31, 2017, 12:07pm
18
Finally got it working.
I am an idiot and was using the pin out on the nodemcu and not the GPIO. How could I be so stupid…
Costas
January 31, 2017, 12:12pm
19
Common mistake, if I was the manufacturer of the WeMos / nodeMCU I would swap the D references to the correct GPIO references.
Edit: just sent my formal request to Mr WeMos. Anyone know Mr / Mrs nodeMCU?
Gunner
Split this topic
April 19, 2017, 8:19pm
20
A post was split to a new topic: I can’t get my IFTTT to work
