Icon selection in icon button
hey Blynkers , do you know if you can input a text on the Icon button instead of the huge choice of useless icons. it shows a hole lot of worthless pic that you would probably never use ?
Wouldn’t it make more sense to use an image button, and create whatever images you require?
I see your point. well noted, but what if you wanted that button to say something in text when turned on instead of displaying an image ?
Add text to your images.
ok I see. thank you as always Pete your the one guy that always comes thru. you should be working for blynk :face_with_monocle::grin:
Of course, the other option is to use a styled button, and set the text, text colour and background colour with the setProperty command.
No thanks, working is an over-rated passtime :wink:
holy **** ! I totally forgot about the styled button ! Ureeka!! that’s the one I need … thank you so much…guess I need new glasses…
