I want to use value from parameter in BLYNK_WRITE() function . How should I do
Myproject about measure temperature and humidity :sweat_smile: :joy:
I use 2 Node MCU , One is Master that receive temperature and humidity value from Sensor 1,Another is Sensor1 (Slave).
Master Code
    char auth[] = "afc3a4ffb11d48efb75eb8b0cf397e10";
    char ssid[] = "Connectify-me";
    char pass[] = "ap123456789";
    float TempSensor1;
    float HumiditySensor1;
    BLYNK_WRITE(V5)
      float TempSensor1 = param.asFloat(); // assigning incoming value from pin V5 to a variable
      // You can also use:
      // String i = param.asStr();
      // double d = param.asDouble();
      Serial.print("TempSensor1 is: ");
      Serial.println(TempSensor1);
    BLYNK_WRITE(V6)
      float HumiditySensor1 = param.asFloat(); // assigning incoming value from pin V5 to a variable
      Serial.print("HumiditySensor1 is: ");
      Serial.println(HumiditySensor1);
Sensor1 (Slave) Code
    #include <DHT.h>
    #define DHTPIN 2
    #define DHTTYPE DHT11
    char auth[] = "c7d8918ccf2c47b3a74afb4a4f9b5cae";
    // Bridge widget on virtual pin 1
    WidgetBridge bridge1(V1);
    DHT dht(DHTPIN, DHTTYPE);
    // Timer for blynking
    void blynkAnotherDevice() // Here we will send HIGH or LOW once per second
      float h = dht.readHumidity();
      // Send value to another device
           bridge1.virtualWrite(V5, t);
           bridge1.virtualWrite(V6, h);// Sends 0 value to BLYNK_WRITE(V5) handler on receiving side.
    BLYNK_CONNECTED() {
      bridge1.setAuthToken("afc3a4ffb11d48efb75eb8b0cf397e10"); // Place the AuthToken of the second hardware here
      Serial.println ("Sensor1 Linked to Master");
      // Call blynkAnotherDevice every second
      timer.setInterval(1000L, blynkAnotherDevice);
In Master Code I want to use TempSensor1 in BLYNK_WRITE(V5) function and HumiditySensor1 in BLYNK_WRITE(V6) function to calculate and adjust error value of parameter in THE VOID LOOP() function such as this code below
Master Code(to use parameter in BLYNK(V5) function)
    float TempSensor1;
    BLYNK_WRITE(V5)
    BLYNK_WRITE(V6)
     int TempSensor1;   // How to get value of   TempSensor1 paremeter in  BLYNK_WRITE(V5) function
     int a;
     int HumiditySensor1;//How to get value of   HumiditySensor1 paremeter in  BLYNK_WRITE(V6)
     int b;
     a=TempSensor1+2
     b=HumiditySensor1+3
      Serial.println(a);
      Serial.println(b);
I try to edit code like C++ but it’s not worked . The code that edit is below
     BLYNK_WRITE(V5)
          return TempSensor1;   //edit*****
        BLYNK_WRITE(V6)
          return HumiditySensor1;  //edit*****
