I Want to Set Notification Limit to 1 sec. plz help me
Hey, Guys I Want The Notification Limit In Events To Be Set to 1 Notification Per 1 Second.Plz Guys Help Me.
Unfortunately, there is a limitation that prevents you from doing that (100 events per device per day). The daily limitation will be exceeded in less than two minutes if you send one notification every second.
Would you mind explaining why would you need a notification every second ?
