I want to Push a Physical button and write on to a virtual pin with it
Greetings,
I want to tie a physical button to an vpin.
For example:
I push the Lightswitch so get a HIGH on pin 13 from my arduino mega 2560 and then it should write an HIGH signal onto the V10 Pin.
Unfortunate im a beginner and got stuck with the scetch.
Here It is :slight_smile:
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - Arduino Mega 2560 board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
#include <Ethernet2.h>
#include <BlynkSimpleEthernet2.h>
char auth[] = "Look at your own ;) ";
  pinMode(13, INPUT);
  int buttonState = 0;
  //Blynk.begin(auth);
  //Blynk.begin(auth, "blynk-cloud.com", 8442);
  Blynk.begin(auth, IPAddress(192,168,1,11), 8442);
BLYNK_WRITE(V10)
 if digitalRead(13 == HIGH)
    Blynk.virtualWrite(10, 255);
  Blynk.virtualWrite(10, 0)
  // to avoid delay() function!
The Problem is that arduino IDE gives out this ERROR code:
sketch_jul08a:72: error: expected ‘;’ before ‘}’ token
exit status 1
expected ‘(’ before ‘digitalRead’
And i dont get it any more. i looked and tried it with the help of docs.blynk ut i think its to difficult :smiley:
Sorry for the bad english (Im from switzerland)
Ok the issue with the IDE is fixed. i forgot some ()
Here is the new scetch:
>   Blynk library is licensed under MIT license
>   This example code is in public domain.
>   You’ll need:
>   example.
> /* Comment this out to disable prints and save space */
> #define BLYNK_PRINT Serial
> #include <SPI.h>
> // You should get Auth Token in the Blynk App.
> // Go to the Project Settings (nut icon).
> char auth[] = "look at you own";
> void setup()
>   // Debug console
>   Serial.begin(9600);
>   pinMode(13, INPUT);
>   // You can also specify server:
> BLYNK_WRITE(V10)
>  if (digitalRead(13 == HIGH))
>  else
>   Blynk.virtualWrite(10, 0);
> void loop()
>   Blynk.run();
>   // You can inject your own code or combine it with other sketches.
>   // Check other examples on how to communicate with Blynk. Remember
Problem is that i got nothing on the V10 pin
You should probably pull pin 13 low In void setup with
digitalWrite(13,LOW);
after the pinMode(13, INPUT); line
I assume your physical switch is connected between 5v positive and pin 13?
Thanks Pete for your fast reply.
I added the line but no effects on the result :frowning:
Im also not sure if i forgot something or using the rong commands in the blynk write section . Or is something missing?
Gretings
I am guessing you are using a Display widget on V10 in the App, as a Button widget would only need a 1 or 0 to indicate feedback of ON or OFF… so not sure why you are pushing a 255 to the widget. EDIT - unless you are using a LED widget, in which case you are not setting it up correctly.
But then this statement is a bit confusing… do you mean you have NO widget, or not seeing any result?
Also, since Pin 13 is also wired to the internal LED of the MEGA, it’s own internal resistor may be adding to some confusion? I generaly avoid it for input purposes, so can’t say for sure.
What you wanted was if (digitalRead(13) == HIGH)
Yep, your sketch doesn’t make much sense right now.
If you go to https://examples.blynk.cc there is an examples called “Sync Physical Button”. You can borrow much of the code from there.
indeet i wantet to use the led widget to show me that the button is pushed.
I have the led widget in the blynk app but its not lighting up :slight_smile:
To eliminate this issue i^ll switched to pin 12
Thanks i didnt see that the ) was missing:)
Over all i look at the examples and test some things out. (its confusing to take bits of a code i dont understant to 100% and put it in my sketch :smiley: )
Thanks for the moment.
I’m glad you seem willing to understand what’s happening in code :slight_smile:
Firstly, you misunderstood BLYNK_WRITE() block. It is called when a state of a virtual pin is changed from elsewhere (e.g. in Blynk app).
So, move your syncing routine out from there and just call it periodically (say 50 ms) with timer.
Also, I believe you want to move int buttonState = 0; variable outside of the setup() (so that it is visible globally) and use it in your syncing routine so you don’t have to call Blynk.virtualWrite() on each timer call.
FINALLY :smiley:
Now i got some results :smiley:
Here is the new code (sorry for taking so much of the example code ;))
  You’ll need:
  example.
char auth[] = "look  at your own";
// Set your LED and physical button pins here
const int ledPin = 50;
const int btnPin = 12;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V10);
  // Alternatively, you could override server state using:
  //Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V10) {
  ledState = param.asInt();
  digitalWrite(ledPin, ledState);
  if (digitalRead(btnPin) == LOW) {
    if (btnState != LOW)
      // Toggle LED state
      ledState = !ledState;
      // Update Button Widget
      Blynk.virtualWrite(V10, ledState);
    btnState = LOW;
    btnState = HIGH;
  pinMode(ledPin, OUTPUT);
  pinMode(btnPin, INPUT_PULLUP);
  // Setup a function to be called every 100 ms
  timer.setInterval(100L, checkPhysicalButton);
Now i get some signals onto the v10 pin.
only problem left is that i have a switch and the signal on v10 is line a self holding electrical cycle.
Info: Now i got the pullup on pin12 and “short” it on GND
Switch on = Pin 12 Low
Switch on → V10 Low
Switch off → V10 Low
Switch on → V10 High
Switch off → V10 High
Switch on → V10 Low
In stead i need :
Switch on → V10 Low
Switch on → V10 Low
Switch on → V10 Low
Switch on → V10 Low
Thanks for the tipp with the examples.
Hi, been following your project with great interest because that’s what I want to do too. I want to use an output from my burglar alarm to notify me through the app on my phone.
Can you tell me if you have got your switch to work as you need it?
Please note timestamps before posting… this is an older topic.
The question you ask is answered (in one of many ways) in a Sketch Builder…
Push Notification Button
Button Poll
Button Interrupt
And probably all over this forum :stuck_out_tongue_winking_eye:
Just Google how to use a transistor or optocoupler to transfer your alarm signal to a TTL safe output for use on your MCU (all that is NOT Blynk specific)
