It’s not good practise to compare a float against an int (or unsigned int in your case)
temp5 is a float
max_temp5 is uint_8
temp5 is a float
max_temp5 is uint_8
I did the work on the bugs. Now void fantempcheck () works exactly. The error was that void fantempcheck () used data types intended for void tempcheck (). Thus, when data processing took place for both void fantempcheck () and void tempcheck (), a comparison error occurred and the algorithm got stuck. (maybe I’m wrong)
Already the whole day void fantempcheck () passes the test and there is no stuck.
Help me understand how Blynk.syncAll () works? There is a task to save the state of the relay after an unplanned reset. I added Blynk.syncAll () to the setup and it works, but only until the 2nd reset.
The controller runs the code being executed. Scheduler starts switching on the relay, for example, an error occurred in the code and the WDT worked.The controller has restarted, the state has reversed to the specified value. But if the reboot occurs again, the relay will not return its state any more, what am I doing wrong?
#define I2C_SCL 5 //d1
#define I2C_SDA 4 //d2
#define humidifier 13
#define Heater 3
#define Fan 2
#define Light 0
#define Pump 14
#define Aero 12
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <EEPROM.h>
#include <Adafruit_Si7021.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
char currentTime[9];
bool clockSync = false;
bool pinValue32;
bool pinValue35;
bool pinValue38;
bool pinValue41;
bool metric = false;
float hum3, temp5;
uint8_t temppin ; // LOW/HIGH
uint8_t eeprom_temp5 ; // Allow/Disallow
uint8_t min_temp5;
uint8_t max_temp5;
bool flag_temp5_off_state = true;
bool flag_temp5_on_state = true;
uint8_t lastsettemp5;
//--------------------------------------- проба для вентилятора--------------------
uint8_t temppin51 ; // LOW/HIGH
uint8_t eeprom_temp51 ; // Allow/Disallow
uint8_t min_temp51;
uint8_t max_temp51;
bool flag_temp51_off_state = true;
bool flag_temp51_on_state = true;
uint8_t lastsettemp51;
uint8_t hum3pin ; // LOW/HIGH
uint8_t eeprom_hum3 ; // Allow/Disallow
uint8_t min_hum3;
uint8_t max_hum3;
bool flag_fany_off_state = true;
bool flag_fany_on_state = true;
uint8_t lastm;
uint8_t lastbutton;
uint8_t lastp;
uint8_t lastsethum3;
char auth[] = "9babcd13";
char ssid[] = "Tool36";
har pass[] = "frekf123";
Adafruit_Si7021 sensor;
SimpleTimer timer1; // sensor timer
SimpleTimer timer2; // humcheck
SimpleTimer timer3; // tempcheck
SimpleTimer timer4; // fantempcheck
unsigned long timestamp3;
WidgetTerminal terminal(V51);
BLYNK_WRITE(V50) // reset
int pinValue = param.asInt();
if (pinValue != lastp && pinValue > 0)
lastp = 0;
ESP.reset();
//-------------Timer pin-----------
BLYNK_WRITE(V32)
int pinValue32 = param.asInt();
digitalWrite(Light, pinValue32);
BLYNK_WRITE(V35)
int pinValue35 = param.asInt();
digitalWrite(Fan, pinValue35);
BLYNK_WRITE(V38)
int pinValue38 = param.asInt();
digitalWrite(Pump, pinValue38);
BLYNK_WRITE(V41)
int pinValue41 = param.asInt();
digitalWrite(Aero, pinValue41);
//---------------Timer pin end-----------------------------
//---------------------TEMP---------------------------------
BLYNK_WRITE(V19) // write EEPROM temp
if (pinValue != lastp && pinValue > 0 && eeprom_temp5 == 1)
lastp = 0;
int EEaddress = 164;
EEPROM.write(EEaddress, min_temp5);
EEaddress++;
EEPROM.write(EEaddress, max_temp5);
EEaddress++;
EEPROM.write(EEaddress, temppin);
EEPROM.commit();
//ESP.reset();
BLYNK_WRITE(V25) // eeprom access temp
eeprom_temp5 = pinValue;
BLYNK_WRITE(V26) // level temp
temppin = pinValue;
BLYNK_WRITE(V20) // setup temp
lastsettemp5 = pinValue;
BLYNK_WRITE(V21) // temp down
if (lastsettemp5 == 1)
if (pinValue != lastp && pinValue > 0 && min_temp5 > 0)
lastp = 0;
min_temp5--;
Blynk.virtualWrite(V23, min_temp5);
if (lastsettemp5 == 0)
if (pinValue != lastp && pinValue > 0 && max_temp5 - min_temp5 > 1)
lastp = 0;
max_temp5--;
Blynk.virtualWrite(V24, max_temp5);
BLYNK_WRITE(V22) // temp up
lastp = 0;
min_temp5++;
if (pinValue != lastp && pinValue > 0 && max_temp5 < 100)
lastp = 0;
max_temp5++;
//---------------------TEMP END-----------------------------
//---------------------HUM---------------------------------
BLYNK_WRITE(V13) // write EEPROM hum
if (pinValue != lastp && pinValue > 0 && eeprom_hum3 == 1)
lastp = 0;
int EEaddress = 161;
EEPROM.write(EEaddress, min_hum3);
EEaddress++;
EEPROM.write(EEaddress, max_hum3);
EEaddress++;
EEPROM.write(EEaddress, hum3pin);
EEPROM.commit();
//ESP.reset();
BLYNK_WRITE(V9) // eeprom access hum
eeprom_hum3 = pinValue;
BLYNK_WRITE(V12) // level hum
hum3pin = pinValue;
BLYNK_WRITE(V14) // setup hum
lastsethum3 = pinValue;
BLYNK_WRITE(V15) // hum down
if (lastsethum3 == 1)
if (pinValue != lastp && pinValue > 0 && min_hum3 > 0)
lastp = 0;
min_hum3--;
Blynk.virtualWrite(V16, min_hum3);
if (lastsethum3 == 0)
if (pinValue != lastp && pinValue > 0 && max_hum3 - min_hum3 > 1)
lastp = 0;
max_hum3--;
Blynk.virtualWrite(V18, max_hum3);
BLYNK_WRITE(V17) // hum up
lastp = 0;
min_hum3++;
if (pinValue != lastp && pinValue > 0 && max_hum3 < 100)
lastp = 0;
max_hum3++;
//---------------------HUM END-----------------------------
/*BLYNK_WRITE(V19) // write EEPROM temp
if (pinValue != lastp && pinValue > 0 && eeprom_temp51 == 1)
lastp = 0;
int EEaddress = 168;
EEPROM.write(EEaddress, min_temp51);
EEaddress++;
EEPROM.write(EEaddress, max_temp51);
EEaddress++;
EEPROM.commit();
//ESP.reset();
eeprom_temp51 = pinValue;
BLYNK_WRITE(V43) // level temp
temppin51 = pinValue;
BLYNK_WRITE(V44) // setup temp
lastsettemp51 = pinValue;
BLYNK_WRITE(V45) // temp down
if (lastsettemp51 == 1)
if (pinValue != lastp && pinValue > 0 && min_temp51 > 0)
lastp = 0;
min_temp51--;
Blynk.virtualWrite(V46, min_temp51);
if (lastsettemp51 == 0)
if (pinValue != lastp && pinValue > 0 && max_temp51 - min_temp51 > 1)
lastp = 0;
max_temp51--;
Blynk.virtualWrite(V47, max_temp51);
BLYNK_WRITE(V48) // temp up
if (lastsettemp51== 1)
lastp = 0;
min_temp51++;
if (pinValue != lastp && pinValue > 0 && max_temp51< 100)
lastp = 0;
max_temp51++;
void tempcheck()
if (temp5 <= min_temp5 && flag_temp5_on_state)
if (temppin == 1 )
digitalWrite(3, LOW); // вкл
Blynk.virtualWrite(V27, 1023); // вкл
Blynk.virtualWrite(V28, 0); // выкл
digitalWrite(3, HIGH); // выкл
Blynk.virtualWrite(V27, 0); // выкл
Blynk.virtualWrite(V28, 1023); // вкл
flag_temp5_on_state = false;
if (temp5 >= max_temp5 && flag_temp5_off_state)
if (temppin == 1 )
digitalWrite(3, HIGH); // вкл
Blynk.virtualWrite(V27, 0); // вкл
Blynk.virtualWrite(V28, 1023); // выкл
digitalWrite(3, LOW); // выкл
Blynk.virtualWrite(V27, 1023); // выкл
flag_temp5_off_state = false;
void humcheck()
if (hum3 <= min_hum3 && flag_fany_on_state)
if (hum3pin == 1 )
digitalWrite(13, LOW); // вкл
Blynk.virtualWrite(V10, 1023); // вкл
Blynk.virtualWrite(V11, 0); // выкл
digitalWrite(13, HIGH); // выкл
Blynk.virtualWrite(V10, 0); // выкл
Blynk.virtualWrite(V11, 1023); // выкл
flag_fany_on_state = false;
if (hum3 >= max_hum3 && flag_fany_off_state)
if (hum3pin == 1 )
digitalWrite(13, HIGH); // вкл
Blynk.virtualWrite(V10, 0); // вкл
digitalWrite(13, LOW); // выкл
Blynk.virtualWrite(V10, 1023); // выкл
flag_fany_off_state = false;
//-----------------auto Fan-----------------
void fantempcheck()
if (temp5 >= max_temp51 && flag_temp51_on_state) //
if (temppin51 == 1 )
digitalWrite(2, LOW); // вкл
Blynk.virtualWrite(V42, 1023); // вкл
Blynk.virtualWrite(V43, 0); // выкл
digitalWrite(2, HIGH); // выкл
Blynk.virtualWrite(V42, 0); // выкл
Blynk.virtualWrite(V43, 1023); // вкл
flag_temp51_on_state = false;
terminal.println("autoFan On ");
terminal.println(temp5);
if (temp5 <= max_temp51 && flag_temp51_off_state) //
digitalWrite(2, HIGH); // вкл
Blynk.virtualWrite(V42, 0); // вкл
Blynk.virtualWrite(V43, 1023); // выкл
digitalWrite(2, LOW); // выкл
Blynk.virtualWrite(V42, 1023); // выкл
flag_temp51_off_state = false;
terminal.println("autoFan Off ");
terminal.flush();
//----------------- end auto Fan-----------------
void sendSensor1()
temp5 = sensor.readTemperature();
hum3 = sensor.readHumidity();
Blynk.virtualWrite(V3, hum3);
Blynk.virtualWrite(V5, temp5);
void readEEPROM(int startAdr, int maxLength, char* dest)
EEPROM.begin(256);
for (int i = 0; i < maxLength; i++)
dest[i] = char(EEPROM.read(startAdr + i));
EEPROM.end();
Wire.begin(I2C_SDA, I2C_SCL);
ESP.wdtDisable();
ESP.wdtEnable(WDTO_8S);
Blynk.syncAll();
ArduinoOTA.setHostname("ESP8266-climat"); //OTA Задаем имя сетевого порта
//ArduinoOTA.setPassword((const char *)"0000"); //OTA Задаем пароль доступа для удаленной прошивки
ArduinoOTA.begin(); //OTA Инициализируем OTA
EEPROM.begin(256);
min_hum3 = EEPROM.read(161);
max_hum3 = EEPROM.read(162);
hum3pin = EEPROM.read(163);
min_temp5 = EEPROM.read(164);
max_temp5 = EEPROM.read(165);
temppin = EEPROM.read(166);
pinMode(13, OUTPUT); // увлажнитель
pinMode(3, OUTPUT); // нагреватель
pinMode(Light, OUTPUT);// свет
digitalWrite(Light, HIGH);
Blynk.virtualWrite(V32, HIGH);
pinMode(Fan, OUTPUT);// вентилятор
digitalWrite(Fan, LOW);
Blynk.virtualWrite(V35, HIGH);
pinMode(Pump, OUTPUT);//помпа воды
digitalWrite(Pump, HIGH);
Blynk.virtualWrite(V38, HIGH);
pinMode(Aero, OUTPUT);//аэратор воды
digitalWrite(Aero, HIGH);
Blynk.virtualWrite(V41, HIGH);
timer.setInterval(58000L, activetoday); // check every 60s if ON / OFF trigger time has been reached
timer.setInterval(1000L, clockDisplay); // check every second if time has been obtained from the server
timer.setInterval(2570L, sendSensor1);
timer.setInterval(2350L, humcheck);
timer.setInterval(2280L, tempcheck);
timer.setInterval(2080L, fantempcheck);
if (min_hum3 <= 30 || min_hum3 >= 99 || max_hum3 <= 30 || max_hum3 >= 99) {
min_hum3 = 65;
max_hum3 = 70;
if (min_temp5 <= 0 || min_temp5 >= 99 || max_temp5 <= 0 || max_temp5 >= 99) {
min_temp5 = 20;
max_temp5 = 26;
if (min_temp51 <= 0 || min_temp51 >= 99 || max_temp51 <= 0 || max_temp51 >= 99) {
min_temp51 = 20;
max_temp51 = 26;
if (!sensor.begin())
Serial.println("Couldn't find sensor!");
while (1);
BLYNK_CONNECTED() {
rtc.begin();
//----------------------------Timer------------------------------
void activetoday(){ // check if schedule should run today
if(year() != 1970){
Blynk.syncVirtual(V30);
Blynk.syncVirtual(V33);
Blynk.syncVirtual(V36);
Blynk.syncVirtual(V39);// sync scheduler #
void clockDisplay(){ // only needs to be done once after time sync
if((year() != 1970) && (clockSync == false)){
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
Serial.println(currentTime);
terminal.println(currentTime);
clockSync = true;
terminal.flush();
BLYNK_WRITE(V30) { // Scheduler #1 Time Input widget
TimeInputParam t(param);
unsigned int nowseconds = ((hour() * 3600) + (minute() * 60) + second());
unsigned int startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
unsigned int stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected((weekday() + dayadjustment))){ //Time library starts week on Sunday, Blynk on Monday
//Schedule is ACTIVE today
if(nowseconds >= startseconds - 31 && nowseconds <= startseconds + 31 ){ // 62s on 60s timer ensures 1 trigger command is sent
digitalWrite(Light, LOW);
Blynk.virtualWrite(V31, 1023); // turn on virtual LED
Blynk.syncVirtual(Light);
Serial.println("Schedule 1 started");
terminal.println("Schedule 1 started");
if(nowseconds >= stopseconds - 31 && nowseconds <= stopseconds + 31 ){ // 62s on 60s timer ensures 1 trigger command is sent
Blynk.virtualWrite(V31, 1); // turn OFF virtual LED
Serial.println("Schedule 1 finished");
terminal.println("Schedule 1 finished");
terminal.flush();
/*BLYNK_WRITE(V33) { // Scheduler #2 Time Input widget
if(weekday() == 1){
Blynk.virtualWrite(V34, 1023); // turn on virtual LED
Serial.println("Schedule 2 started");
digitalWrite(Fan, HIGH);
Blynk.virtualWrite(V34, 1); // turn OFF virtual LED
Serial.println("Schedule 2 finished");
BLYNK_WRITE(V36) { // Scheduler #3 Time Input widget
if(weekday() == 1){
digitalWrite(Pump, LOW);
Blynk.virtualWrite(V37, 1023); // turn on virtual LED
Serial.println("Schedule 3 started");
terminal.println("Schedule 3 started");
Blynk.virtualWrite(V37, 1); // turn OFF virtual LED
Serial.println("Schedule 3 finished");
terminal.println("Schedule 3 finished");
terminal.flush();
BLYNK_WRITE(V39) { // Scheduler #4 Time Input widget
if(weekday() == 1){
digitalWrite(Aero, LOW);
Blynk.virtualWrite(V40, 1023); // turn on virtual LED
Serial.println("Schedule 4 started");
terminal.println("Schedule 4 started");
Blynk.virtualWrite(V40, 1); // turn OFF virtual LED
Serial.println("Schedule 4 finished");
terminal.println("Schedule 4 finished");
//-------------------------timer end--------------------
if(Blynk.connected()){
ESP.wdtFeed();
ArduinoOTA.handle();
How many Blynk virtual object do you sync?
Thank you, I found an error in the code. It was necessary to place in the void setup()
