I want help on using map
I just added map widget and it shows my location . I have same project(my complete home automation) running on all family members phone.Each of the phone shows their respective location.Is it possible that it shows location of only for my kid?Hope that I explained my problem or issue properly.All members are logging using my credentials.
Hello. This is not a use case for map. Map is designed to be used from hardware side. You may do a workaround like send coords to hardware and than send back to app.
Thanks . I have no idea how to do it.Any link or example will help.
Regards,
You need to combine 2 example - gps example and this
