Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
@Vlad_Hristov Are we looking at the same topic? I see a “I wanna” and a "how can i do it with blynk? "… but not a single instruction (the posts only contents are the default for all new topics… meant to be followed, and replaced with required details.)
You might be right. Even when is a title, people might consider it as their same concern/Q. After his/her response, it seems they are asking for help @Bijinicb
Yes, I was, almost like I have been doing this for awhile
And BTW, you do NOT need to install a Local Server (an advanced option compared to the Cloud Server) just to use email notifications on Blynk… so no need to complicate the issue please.
