I’ve made two simple Blynk apps with two auth codes. How can I combine them into a single window?
I’ve made two simple Blynk apps with two auth codes. How can I combine them into a single window or App ?
AFAIK you can’t.
You can leave them as separate projects and use bridge / API to interface between the two.
Other than that you need to move one project, widget by widget, by hand.
I’m basically using a Gps tracker Blynk app and a Relay Blynk app with different auth codes on an esp8266 module, neo 6m gps module and 8 channel relay module
( not using all relays )
Just write down the pin and widget details from the smallest project and recreate on the bigger one.
