I need to reset router if i whant to connect blynk?
hello,
i have arduino mega 2560 and enc28j60 and configured blynk every thing was OK but couple days ago i got problem :frowning:
If Blynk disconnect i can not connect but if i reset my router Blynk is connecting without problem .
Did some one have similar problem ?
anyone ?
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
Try to reset your router. You can do it in two different ways. The first one is the most used way, but you will have to setup your router once again, to enter the IP address, mask, and other things to make your internet connection working. So to say, I would definitely recommend you to use the second way of solving this problem. Firstly, read this article https://www.router-reset.com/ip/192-168-100-1 and you will never have this question once again. In this article you will find all the necessary information to reset your router from the router’s administrator panel. It is pretty easy and you will be able to do it by yoursef, more than that you will be able to do that whenever you need without asking around how to reset your router
