hi, i need help, is this connected to my wifi? or not?
!if that’s connect , but why, it’s allways offline in my phone.
Thank you
Thank you
“Connected to wifi” does not implictly mean “connected to blynk” …
Is the Blynk token correctly set?
i don’t know , i set my project in blynk is for arduino mega and the connection is wi-fi , is this correct?
Ok for the app side.
The Blynk token goes into the code for the mega. Is …
… correctly set?
This seems to be correctly set as you get connected to wifi:
char pass[] = "YourPassword";
I assume you base your tests on this example, right?
